Question about Nikko RC Hummer H2 Off Road Truck
I have a Nikko Phoenix which will not respond. It has a 7.2 V NiMH battery. I have replaced and checked batteries in both car and control. It is a 27 MHz control. When I connect the main battery the car "reacts", makes a buzz, but it will not respond to steering or motor. The car has hardly been used. Is there any thing I can test?
2 Suggested Answers
  • 49 Answers
SOURCE: We have two Nikko remote control cars and since
Hi ken, if your nikko cars are dont seem to work check te conection cable maybe you need to cleened a little bit if you make it and dont work try to change the beterries again if they are rechargable or only use baterries AA
Posted on Jun 17, 2009
Nikko 900012A2
Transmitter battery are ok ? Is there any led showing power on it ? If it is a 2.4GHz ( small antenna ) could be a bind procedure that need to be done, check for bindings in your manual. If 27Mhz make shure both antenna are depoyed completly.
Nov 25, 2013 | Toys
I have nikko infra-red control that has a little car that sets on the top of the hand control to charge the battery. The battery in the car is missing but on the battery tab it has irc-4 can you tell me...
I have the same little remote control car. I took my battery out to clean the terminals, and found the number on it to be 1BA1R2N120M. This is many years after your original post, but it may help someone.
John M.
Aug 26, 2011 | Nikko Toys
Remote control is messed up. car runs independently of control settings. won't stop. steering control doesn't respond. car worked fine when last used about two years ago. has been sitting in a...
Dear Jereed7,
Have you tried to change the batteries of the controller?
When you haven't used it for two years, then i would try that in the first place.
I hope I helped you with your problem.
With kind regards,
MisterN
Aug 10, 2011 | Nikko Toys
What charger should I get for my Evader EXB
I show your car uses 8 “AA” batteries, 6- or 7-cell NiCd or NiMH battery.
Radio Shack or The Shack will have a replacement and the store people should be able to guide you to the correct plug and polarity. NiCD and NiMH batteries are easy to work with, buy, replace and charge. If you use 8 AA batteries, that is 8 X 1.5 (volts) = 12 Volts DC. NiCD and NiMH style batteries should deliver about the same but dont expect to get performance from a NiCad battery as they dont offer enough power.
Apr 09, 2010 | DURATRAX Evader Exb 1/10 Electric Buggy...
NIKKO CAR CIRCUIT DIAGRAM C1059CA DATASHEET
my Grandson got a modern mustang radio controlled car last Christmas. One to many slamming it into things, one of the battery wires came undone. The brown wire, if that helps. I need to know where it reconnects to?
Thanks
Dec 16, 2009 | Nikko Toys
We have two Nikko remote control cars and since the batteries have gone out (and since been replaced) they no longer work. On each car, a + battery connection is plastic? is that normal?
Jun 15, 2009 | Nikko Toys
Receiver Card (bad)
I HAVE A IDEA WHI DONT YOU SEARCH AT YOUR LOCAL TRIFT STORE AND FIND A NIKKO TOY CAR WITH THE SAME FRECUENCY 27 OR 49 MHZ IT DOESNT MATER IF THE CAR WORK WITH BATTERIES THE ONLY THING YOU MUST CHECK IS THAT THE CAR WORKS WITH 6 BATERRIES THE CAR CAN BE IN PIECES BUT IT CANT WORK TO USE THE CARD THAT IT HAS AND USE IT IN YOUR TRUCK IF YOU FIND IT SEND MI A MAIL AND I CANT TELL YOU HOU TO MAKE IT WORK AND BUT A RECHARGABLE BATERIEI HOPE THIS CAN HELP YOU
May 14, 2009 | Nikko RC Hummer H2 Off Road Truck
Wireless mouse will not connect or respond
Insert the new batteries, making sure that the positive(+) and negative (-) ends of each battery match the polarity indicators inside the battery housing.
When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never use an
alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device. Slide the battery cover back into position until it “clicks” firmly into place. Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse, glows red.
6 Just somethings to check, One other thing to take a peek at, on the transmitter look to see is there is a tiny button that may say connect or reconnect. You may need a pen if you have chubby fingers like me.
Hope this helped, please leave a rating,
thank you kindly
May 02, 2009 | Computers & Internet
Hummer truck will not go foward
the maninboard of the nikko car is broken you may need to change it or look for it at ebay or search in a second hand store and find a cheap card with the same tipe of baterrie and model to buy it for replacement parts
Dec 12, 2008 | Nikko RC Hummer H2 Off Road Truck
Nikko RC Hummer H2 Off Road Truck Logo
81 people viewed this question
Top Nikko Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Nikko Toy Expert? Answer questions, earn points and help others
