Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Pointer "B" was moved, contrary
Http://waterheatertimer.org/Paragon-timers-and-manuals.html
The link above shows all the Paragon timers.
If you have the Paragon 4000 mechanical timer, then the pointer is at the 8:00 position.
To set current time, you lift and rotate white dial until current time lines up with the 8:00 position
If this is not your timer, then add a comment with your timer and model number and I'll look it up.
pointer
Posted on Nov 07, 2010
Testimonial: "Thanks a million! The pointer was moved to the 6 o'clock position and I could not get it to work right."
Touch screen works with mouse pointer in vertical direction, but in horizontal the point of touching is not where the pointer appears. must touch to the left of button you want to push.
See if you can find the touch screen setting in control panel and go through the calibration Setup, with a bit of luck that will be all you need to do
Nov 01, 2016 | Computers & Internet
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Moved pointer intermatic T104
The time pointer is supposed to be stationary.
On T104 timer the pointer is stationary pointed downward at 6:00 position. So you can move it so it is pointed straight down and add a bit of super glue where pointer meets stem.
Copy following link for instructions how to set T104 timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Jul 05, 2012 | Intermatic T104 24h 208-277v Mechanical...
Oven is off 100 degrees. How to calibrate it?
To Adjust the Thermostat
Pull the OVEN TEMP knob off the shaft. look at the back of the knob and note the current setting before making any adjustment. The knob is factory set wit the knob directly under the pointer.
1. Pull of the OVEN TEMP knob
2. Loosen both screws on back of the knob
3. Adjust lower screw so it moves in the desired direction. You will hear and feel the notches as you turn the knob. Each notch changes the temperature about 10 degrees F.
4. Tighten the screws.
5. Return the OVEN TEMP knob to the oven.
Re-check oven performance and make the necessary adjustments accordingly.
Feb 12, 2011 | GE Spacemaker JMS08 Electric Kitchen Range
Toshiba Tecra: How to turn of directional buttons
I'll bet it's the mouse in the keyboard that is at fault rather than your left arrow. Try pressing the little joystick mouse device in between the G and H key and above the B key to the right when your pointer drifts to the left. If it's the joystick moving it and then letting it rest should re calibrate it.
Let us know whether or not the joystick is the culprit or not so we may continue to help you?
Sep 06, 2008 | Computers & Internet
I don't think you can turn them off.
Check the mouse in the keyboard it could be at fault rather than your left arrow key/switch. Try pressing the little joystick mouse device in between the G and H key and above the B key to the right when your pointer drifts to the left. If it's the keyboard's joystick then moving it a little and then letting it rest should re calibrate it.
Let us know whether or not the keyboards joystick is the culprit or not so we may continue to help you?
Parkinson cowan sonata 55x gas cooker
When foods come out burned, soggy, or unevenly baked, it generally means heat isn't being distributed evenly throughout the oven, it's escaping out the door, or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven.
2) Check the door gasket, and, if necessary, replace it.
3) Be sure nothing is obstructing the vent.
4) Reposition the oven racks so baking pans aren't too close to the heat sources.
5) Check your baking pans. If they're dark, they may be burning your food. Reduce the temperature by 25 degrees Fahrenheit when baking in dark metal or glass pans.
You can also recalibrate the controls. If your oven has calibration right on the knob, you can calibrate the appliance as follows. If it doesn't, call an appliance repairperson. To adjust the thermostat's calibration:
1) Remove the oven temperature knob by pulling it off its shaft.
2) Notice the current setting, and then move the pointer in either direction to adjust its temperature slightly up or down. It's intentionally difficult to move the pointer on some models; if this is the case, you'll have to remove a couple of screws. Figure that moving it one notch will change the setting by 10 degrees Fahrenheit.
3) For more accurate calibration, call an appliance repairperson.
Do rate the solution i need it!!
Jun 17, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
125 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
jdthefixer
Andrew Taylor
Andrew Taylor
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
