Question about Refrigerators
GE Refrigerator PSS26SGPASS Will Not Dispense Ice or Water
Unit would intermittently dispense ice and water, but nowwill not dispense either. Ice maker is working fine---this is just adispensing issue. No lights are illuminated on the display unit. Refrigerator and freezer working fine otherwise. There is 13.5 VDC coming offthe red and black wires associated with the "Board Assembly MainControl" GE part number WR55X10552. However, only 1.2 VDC appears at the 6pin connector on the red and black wires (power and common) on the display unitWR55X10298. I trust 13.5 VDC should also be present there. I havejust the replaced the latter with no change in symptoms. Regardless it needed tobe changed out because front panel was cracking in front of water switchand ice switch after just 3 years or so.
Any help or insight that you could provide would be greatly appreciated.
  • 770 Answers
Yes the power shopuld be there as well..One time i had the same issue and found a mouse had chewed partially thru the wire !!!! Trace it(wires) back down the bottom of the unit left side as it come out the bottom of the door and go towards the back to the board. see if you see a break in there
If you want the service manual post your email here i will send it to you
Posted on Jun 15, 2008
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Hi, I have a GE pcf23ngtd side by side. It makes ice fine, but it doesn't dispense any ice and intermittently dispenses water. Any thought of what the problem is?
you have a pinched water supply line -
not sure on why it would not dispense ice unless there is some blockage or other -
did you remove all the ice tray and fully inspect the dispenser at both sides of the door -
Feb 13, 2011 | GE Profile CustomStyle PCF23NGT Side by...
How to remove front panel from ge ice maker model PSS26SGPASS
If you are talking about the ice/water dispenser palnel, on my PSF26NGPABB Arctica it just pulled off. there is double sided tape all the way around it and I used a thin, sharp knife to cut it as I pulled the panel off.
Jul 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
GE refrigerator GSS25JFMCWW not dispensing ice but dispense water
I have the same problem with the same unit. I removed the ice tray and held the open door cut-off switch closed. I then pressed the lever to dispense ice. I hear a humm like power is getting to the motor but the motor is not turning. I hear a click like the selonid is engaging. I'm having to assume at this point it's the motor and I am going to go ahead and order a motor. I've found a motor for the unit at partselect.com for $65.54. Hope this helps you.
Apr 21, 2009 | GE GSS25JFM Side by Side Refrigerator
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ge refrigerator makes ice but does not dispense ice
FROZE UP RESEVOIR BEHIND REFRIGERATOR DRAWERS. PULL OUT FRUIT AND SNACK DRAWERS AND DEFROST WITH BOILING WATER OR A HAIR DRYER.
Nov 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
445 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
