Question about Princeton Digital VL1716 17" LCD Monitor
Need cable and power supply
Where can I get a new cable and power supply for this monitor??
Power Adapter Input AC 100-240V, 50-60Hz, Output DC 12V/4.0A
This may help. Just make sure you have the right dc output mentioned on the back of your monitor (12v4a or 12v5a) if any lower your monitor will shut off after displaying for few seconds then electrical smell will come out from your ac/dc adapter. When it overheats it shuts off.
http://www.alibaba.com/product-gs/51210391/TFT_AC_Adapter_for_12v_4a.html
Manual
http://www.princetongraphics.com/site/download/manuals/vl1716.pdf
Posted on Feb 14, 2009
Do I need both cables for windows machine or can the USB connected to the machine and the mini dp plugged into the monitor work by itself
Is this an external monitor cable? Where the monitor cable that connects to the computer has two USB cables attached at one end?
If so, no. You do not need to plug both ends in. If one is powering the monitor fine and you see no performance problem occurring with the monitor you are OK to plug in just one.
The extra USB end connected to the cable is for additional power supply. If for some reason the machine you are plugging into does not supply enough power to the external monitor you would plug the second end it to the machine and boost the power to the monitor.
Hope that helps.
Oct 20, 2015 | Computers & Internet
Replace power supply for mitsubishi LT-52148
see this instruction. God bless you
    • 1
      Unplug the monitor power cable. You should never attempt to disassemble an electronic component without first detaching it from its direct power source.
    • 2
      Remove the screws from the back of the monitor and along the edge of the screen. Depending on manufacturer and model, LCD monitors will have screws located on different parts of the monitor's body. Once the screws are off, use a flat-tipped tool, such as a knife or a screwdriver, to pry the monitor open by dislodging the two halves; be careful not to tear wires connecting the two halves.
    • Sponsored Links
    • 3
      Locate the power supply unit and take its metal casing off. Once again, different models of LCD monitors will have the unit placed in different locations. With the casing undone, unplug cables running from the power supply to other internal components. Mark the cables that you unplug from the power supply--you will have to plug them back in to the new unit.
    • 4
      Dislodge the power supply from its dock. In some monitors you might have to undo screws that hold the power supply unit in place. Remember the orientation of the unit as it was placed, because you will have to insert the new unit in exactly the same way.
    • 5
      Insert the new power supply into the dock and screw it in place. If you do not have a new power supply, read the label on the existing one to order a new one from the manufacturer or from a third-party supplier. Obtain a power supply unit that is compatible with your LCD monitor; never try to use a generic spare. After installing the new unit, plug in the cables exactly as they were in the old unit.
    • 6
      Put the power supply casing back on and reassemble the LCD monitor frame. Gently clasp the two halves of the monitor shut, making sure you have reattached all cables that you unplugged to take the monitor apart. Close the casing, tucking away all cables neatly so they do not get in the way of the monitor casing.
    • 7
      Put all the screws back on. Once done, you should have no leftover pieces (screws or cables).
Read more: http://www.ehow.com/how_6165539_replace-lcd-monitor-power-supply.html#ixzz2ZJV8TbYP
Jul 17, 2013 | Mitsubishi LT-52148 52-Inch 1080p LCD HDTV
IWe have replaced the Acer F1 pc power supply with a new one, still no start up power. Power supply does not start, no fan spinning?
Try using a differrent power cable, you could use the cable which goes to the monitor. If that works, then you need to just get a replacement power cable (could be US 3 PIN Spec).
If that doesn't work, then the power supply of the computer tower needs to be replaced.
Oct 25, 2010 | AcerPower F1 PC Desktop
What I need to do when my new computer does not wants to run, the problem is in the CPU, the botton start doesn't want to turn on
New PC,s are tested at the factory before they are shipped. So you need to check ALL your data and power cables as well as your AC power outlet before you report the problem to Gateway.
1. Does the power LED on the monitor light up after your connect it to AC power and turn the power switch on? If not, plug a lamp or other electrical device into the AC outlet you are using for your PC and monitor to make sure you have AC power.
2. On the rear of the PC make sure the the AC power switch on the power supply is in the on position. (Some power supplies do not have this switch) Also, make sure the AC power cable connector is fully inserted into the 3 pin power receptacle on the PC's power supply.
3. Make sure that the monitor, keyboard and mouse cables are connected to the proper receptacles on the rear or yur PC.
4. If the PV still will not power up, call Gateway tech support and tell them abouts the tests you have performed - they will probably arrange to send a technician to test your PC.
Oct 23, 2010 | Gateway FPD2275W LCD Monitor
When I turn it on it runs for about ten minutes. Off and on again it runs for maybe 5, then 3, then 2. What should I look for?
Sounds like power supply or the cable may be bad. Try another monitor on same cable or same monitor on different computer with same or different cable exchanging components until problem stops. It may be the power supply to your computer is getting bad and cannot support the power requirements you need. OR, it may be that the monitor is starting to need internal component, like relays of power supplies for itself. Try the other stuff first.
Hope this helps.
Brock
Sep 16, 2010 | LG W1934S-BN 19" Monitor
New install Acer x223w monitor
You would only need that cable if the other end requires a VGA end. Happy Holidays
Dec 17, 2008 | Acer 22" X223w LCD Monitor
Power problem
for the quickest fix, you should try a new power supply cord and see if its just a bad cable. almost any monitor cable (dell brand) should work. if you do not see any of the lights on the monitor light up then you have an internal problem and it will be costly to repair. probably better of buying a new monitor.
Sep 25, 2008 | Dell E153FPT 15" Flat Panel LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Need new power cord for x2gen monitor
You should be able to go to any local store like BestBuy and pick up a power cable. The monitor uses the same power cable as a Desktop PC.
Here is a picture: http://www.cablestogo.com/product.asp?cat%5Fid=914&sku=03129
Mar 14, 2008 | X2Gen MG19MY 19" LCD Monitor
Princeton Digital VL1716 17" LCD Monitor Logo
299 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
