Question about Fogel FLP-278 Commercial Refrigerator
Hi. I have a Fogel FLP - 27 - 8 sandwich prep fridge. It has started getting colder all of a sudden and is freezing. The temp gets down to 25 or so even tho I have the setting set on 1 now in an attempt to get it back up to 41. It will fluctuate though and is causing food loss. Is this a simple thermostat problem or could there be a larger problem. Also where can I get parts for this model?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: why is my fogel sandwich prep getting too cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 27, 2010
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
Metalfrio prep table freezing evapoator
Check that all vent areas are clear of any dust or food packaging. If you have ice build up it needs to be thawed out also because it will only continue freezing until it gets proper airflow.
Sep 17, 2014 | Metalfrio SCL2-60-16 Salad Sandwich Prep...
How do I make fridge temp colder?
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | Danby Refrigerators
Items in refrigerator are freezing
The temp control in the fridge actually moves the flap the opens and closes in the venting between fridge and freezer. This vent can get stuck or frozen in one direction. A good thawing out which is recommend once a year for any unit is not a bad idea.
Thawing of this vent and flap are a good idea. Once it is thawed out or unstuck, then move the temp control around to see if the flap will move. Then you can turn it down so freezer is colder and fridge is not freezing up.
Jan 25, 2011 | Samsung Refrigerators
Why is my fogel sandwich prep getting too cold
heatman101
Oct 29, 2010 | Fogel FLP-278 Commercial Refrigerator
I got a true refrigeration sandwich prep table it will get down to temp. But as soon as it gets down to about 38 it will start frosting up all the way back to the compressor and by the next day it has...
Look for doors not properly closing, poor air flow over coil or something blocking air flow, improper freon level.
http://www.truemfg.com/pdf/InstallManuals/TPP_TSSU_TUC_TWT/tuc_english.pdf
check out this web site as it has a manual for your equipment. it has lots of good info. Hope this helps. If you need more help, let me know.
May 19, 2010 | True 598-TSSU608ADA SandwichSalad Unit 155...
Food freezes in the fridge part even at the highest
If it is freezing, either you need to turn both temp down to 2nd to lowest setting. Cold air does sink, so that is why crisper gets colder. There is a flap and vent for air between the fridge and freezer. The flap can get stuck in one direction, or the acutator that moves it can become faulty. A leaky door seal will also make the opposite compartment colder.
Oct 11, 2009 | Frigidaire GLRS263ZD Side by Side...
Sandwich prep refrigerator too warm.
It sounds as though you have a clogged capillary tube, cannot be sure without suction and liquid line pressures and temps but if you can, ask the tech if the suction pressure seemed to be low, if so, replace the capillary tube with the proper length and diameter tube, replace the liquid line dryer and pull a GOOD vacuum on the system and recharge it, refering to the rating plate for the proper amount and type of refrigerant.
Jun 22, 2009 | Fogel FOG-FLP4512 Undercounter Sandwich...
Fogel FLP-278 Commercial Refrigerator Logo
47 people viewed this question
Top Fogel Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Fogel Refrigerator Expert? Answer questions, earn points and help others
