Question about Magic Chef CMV1000B Microwave Oven
DOOR HANDLE After paying almost $300 for this micowave @ HomeDepo in Canada- the door handle snapped right off,only after 2mths of using it.Now I have to use a knife to open it!!!.Anyone know where to order one of these?
  • 100 Answers
Here's the direct link to MC's parts order page...
http://www.magicchef-ewave.com/default2.asp
Posted on Jun 30, 2008
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
I need. To replace the handle for a kitchen aid microwave. I have the new part but it came with no instructions. I am afraid to do to break the microwave model# KHMS155L 0. Any one who knows where to...
Here's an exploded view of the door:
Item 10, the door panel, just snaps over the rest of the assembly. If you work slowly and carefully with a flat object like a putty knife, you can separate the door panel and take it off without damage. This will expose the screws (number 8) which hold the handle on. Then you just need to snap the door panel back into replace after you put on the new handle.
Good luck and thanks for using Fixya!
May 15, 2011 | KitchenAid Microwave Ovens
Samsung microwave door handle snapped off and I found replacement parts but How do I get to the back of the handle to replace it?
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 18, 2009 | Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Outside panel cracked
Around the inside door there should be a plastic piece of trim right around the window. Take a flat screwdriver and pry it up all the way around. They do break kind of easy but it is a snap fit. Once thats off you can see the rest of the screws and snaps.
Feb 15, 2009 | Microwave Ovens
Broken Plate
Contact Danby Customer Service US / Canada
Feb 13, 2009 | Danby DMW650 700 Watts Microwave Oven
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Jul 29, 2008 | Microwave Ovens
Microwave door handle replacement
Solution for GE Spacemaker Ovens (my model is JVM1650BH05)
1- Remove door by lifting it out of hinges. You will need to remove grille first (2 set screws).
2- Carefully pry off the plastic inside door trim. Use a fine knife or putty knife. There are 10 tabs holding the trim from behind. It's OK if you break a tab! Try to pull out as straight as possible.
3- Once the trim is off, remove the 2 visible screws that hold the door handle. NOTE: There are 2 invisible screws so you are not done yet!
4- You now need to remove the metal ring that holds the latches. To do that, grab the metal ring and using your other hand, release each plastic tab one by one (same tabs as above).
5- Once the metal ring is loose, you will see 2 screws. Remove them if they are still there.
6- Position your new handle and attach using the first 2 screws.
7- Reposition the metal ring by re-snapping it in place. Install the other 2 screws.
8- Replace the plastic trim by snapping it back in place
9- Reinstall door and grille. Tell wife or hubby that you are a genius!
Bonus: use metal washers when screwing down the 2 first screws.
Mar 10, 2008 | Microwave Ovens
Microwave door handle keeps breaking-
Hi - I also have GE profile spacesaver and the handle broke on the bottom only, did not want to spend money on a new handle. Put clear silicone make sure you put enough on and masking tape to hold it overnight has not come off in over a year, any ecess silicone just remove it with hands. Cheap and excellent solution.
Oct 29, 2007 | Microwave Ovens
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Magic Chef CMV1000B Microwave Oven Logo
145 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
