Question about GPS
My Navman S50 touchpad depresses the wrong key. When i try to enter an address or move to the next screen from the main menu by pressing in the bottom right hand corner the box or item above depresses instead. Makes it hard to do much. Can anyone help
  • pyro2 Nov 06, 2010
    Thanks, now to buy another GPS
    President:
  • 2,777 Answers
This is a problem with the Digitizer on your device. It is the piece of the electronics that detects when and where you touch the screen, they do just wear out after a time. You can try resetting the GPS by going into PREFERENCES on the device and finding RESET GPS. However it most likely will not fix the issue. It is repairable but to repair the digitizer is just as expensive as replacing the whole unit unfortunately.
If you think it's still under warranty they will definitely fix this issue for free. Otherwise you may want to look into buying a replacement unit and selling this one on ebay listing it as having the issue it does. Someone will buy it and use it for parts, or just put up with the digitizer issues.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 06, 2010
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
My mouse pad doesent work
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Nov 28, 2012 | Acer Aspire 7741Z-5731
How to unlock keyboard and mouse pad
Shortcut Key Method
hope this helps
Oct 07, 2012 | Samsung Computers & Internet
We moved to a new location and I would like to change the address on the machine. How do I do that?
You can change the address on the receipt header by going into the Setup menu. The options will be different based on who your credit card processor is. Different companies use different programs. However, the basic menu structure is pretty similar. Go into the "Merchant" option and hit F2 for Next until you see the Header Line 2 value. Press F3 to Edit. Type the new address, using the ALPHA key to make letters. Space is 0 alpha alpha. When completed, press the green Enter key. Do the same for Header Line 3. Press F4 to exit. It will ask you if you want to save changes, choose "OK." Press the red X key until you get back to the main screen.
NOTE: Changing what prints on the receipt header will not change the information on your merchant account. You still need to call the merchant services provider and provide them with your new address.
Jul 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
NAVMAN S45 GPS SET UP
http://www8.garmin.com/manuals/nuvi750-GPS-Atl_OwnersManual.pdf
click the link
model is different but system is same.
Dec 17, 2008 | GPS
Navman S50 not download Nokia 6600 slide phone book
The Nokia 6600 is not fully compatible with the S50. Check the Navman website for the bluetooth compatiblity. That model is not listed, Navman do state that not all features are possible.
Dec 05, 2008 | LG CU500 Cellular Phone
Problem with my Navman s50
hmmm..sounds like you are suffering from a firmware issue..have you downloaded any updates recently?
Mar 22, 2008 | GPS
Navman S50 - New Zealand Unlock Code
Try www.computerdirect.co.nz they have the best deal on the map unlock codes (especially with online cash discount)
Jan 10, 2008 | RIM BlackBerry Pearl 8100
Navman S50
My Navman S50 has been working fine the other day it decided to show me the safety agreement when switched on then shows half the screen black with navman S50 printed in the black section the other half shows a picture of a pretty womans face looking backwards from a car window. I can get to the main menu and then takes me in a circle back to the safety agreement I've tried resetting by holding the on off switch down for 6 seconds when switching off the device is there any other way to reset my navman S50.
Dec 30, 2007 | Audio Players & Recorders
GPS Logo
48 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
