Question about Rainbow E series Canister Wet/Dry Vacuum
Plugged vacuum in and no power - Rainbow E series Canister Wet/Dry Vacuum
  • 157 Answers
Hook up your power head and see if it works. If it does, most likely the problem is in your main unit motor resistor. If it doesn't, then check another outlet. Still no function, switch or loose connection inside.
Posted on Nov 06, 2010
Why won't power nozzle attachment turn on?
you may not have power coming from the vacuum. those plugs are known to fail.
Sep 02, 2015 | Electrolux Vacuums
Power nozzle motor not working on my rainbow e2 vacuum?
Check plugin on the power nozzle and poles there may be some thing blocking connections
Dec 28, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
The brush is not working when I turn the power on and the belt appears to be on and intact. How do I fix it?
This is actually a bad design by Bissell. Remove the Lift-Off portion of your vacuum cleaner. Down at the bottom, where the Lift-Off portion was sitting, you should see a small electrical plug part. What usually happens is this plug arc's, which causes it to burn the plug, and stop the power nozzle from spinning. If you see any black, or burning around this plug, take your vacuum back into Bissell, they will fix this, or give you a new vacuum for free. They don't even sell us their warranty stations this plug piece, you can only exchange it for a new vacuum.
If this is not burned, check the reset button for the brush, it's either located near the plug, or on the side of the brush portion of the vacuum.
I hope this was helpful to you.
Chris Jones
goVacuum.com
Jan 08, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
All of a sudden the vacuum started sounding different and the suction was only about 30% of what it normally is.
If the sound of the vacuum changed and it lost most of the power it sounds like you picked up something that plugged it.check your hose and intake to the machine. You can take the hose off and drop a coin through it to see if it is plugged. Check the power head to see if something is plugging it .
Oct 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Pushing the power switch does not turn on the vacuum.
The only fuse is in the plug if this blow then it might trip the CB out
Aug 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Plug gets hot when using vacuum.Could it be the motor? My husband thinks it's because it is drawing to much power. That the vacuum is blocked somewhere.
Do you mean the plug in the wall gets hot if so this should never happen has the fuse in the plug been changed?
if not the vacum can not be pulling to much power as the fuse will blow to stop that
Yes the vacuum may be blocked some where but should be easy to find out where as these models come apart with ease
Jul 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Hoover vacuum model - U6317-930 lost power. I
Something is definitely loose in that area. Replacing the related parts is probably the best fix.
Jul 17, 2009 | Vacuums
My Eureka Whirlwind vacuum on-off switch won't turn off
the power switch is bad. go to your local hardware store and buy a new power switch and replace it.
Mar 23, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
My hoover power drive vacuum simply died. It just shut off. I checked the plug, etc...I just can't get any power...Can you help?
If no light or motor sound cord is probably bad. Look near AC plug or just replace the plug end. Check with ohmmeter for continuity with switch ON.
Jan 24, 2009 | Hoover U6311-930 Power Drive Bagged...
Rainbow E series Canister Wet/Dry Vacuum Logo
120 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Robert McClure
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
