SOURCE: Washer will not drain properly.
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
SOURCE: Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
SOURCE: Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
SOURCE: washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
SOURCE: Washer stopped during wash cycle, burning smell
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/index.aspx Take a look at what a new motor costs for your machine and go from there. Is may not be a motor is could be a belt or a bearing. I rebiult a washer for less then 50 dollars that one did not need a motor just bearings and a belt. I would take the washer apart so you can get an idea of what went wrong and then look at parts to repair it and decide what to do good luck
