Question about KitchenAid KGSS907SSS Gas Kitchen Range
My KitchenAid KGSS907SSS Gas Kitchen Range locked up when the self clean function was used. I had a technician unlock it but now it would not heat. Can you give me a list of the parts that I should purchase to solve this problem. Apparently many other owners of this oven is having similar problems.
  • 10,515 Answers
To start with, kindly provide few more details :-
1. Do you see any problem with the door? what he actually did to resolve the door problem?
2. Do you see any error message?
3. Is this ' not heat ' issue a new one or have you experienced the same issue earlier?
4. Did you run the self clean function again?
5. How long this problem of self cleaning was there?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
Oven door won't close
You should not have been able t force the oven open when in self cleaning mode since u did I am sure that you have damaged the locking mechanism and the solenoid lock inside the top of the oven that sets the lock when doing self cleaning.
this is not a huge problem but it needs to be fixed most likely not by u call an appliance rpair shop in your area and it should cost no more than $150 to fix
Feb 12, 2018 | KitchenAid KGSS907SSS Gas Kitchen Range
Kitchenaid kgss907sss neither the broiler nor the oven will heat with fire. the elecricburner does work however but does not heat well enough. i can hear the igniter click once after turning it on but...
For broil burner ignition an oven broiler burner spark electrode is used to ignite the gas. The electrode is a device that sits right next to the broil burner. It functions like a spark plug. As power is applied to it a spark jumps from the spark electrode tip to the to the electrode shield, igniting the gas. If the electrode is broken or worn out the spark may not occur or be intermittent. Visually inspect the electrode assembly for cracks in the porcelain housing or damage to the electrode tip itself. Be aware that a proper ground and the correct polarity of the incoming voltage to the range is necessary for the electrode control to sense the presence of a flame once the burner is ignited.
there is also a spark control module but I don't think that's it usually no spark when bad.
if you need or want parts ck here for your unit.
hope this helps a little
https://www.repairclinic.com/Shop-For-Parts/-x6b677373393037737373/Kgss907sss-Parts
Jan 05, 2018 | KitchenAid KGSS907SSS Gas Kitchen Range
I ran a self cleaning for the first time this morning since owning the oven since 2/09. now the oven door wont unlock & the control panel is blank. from what I understand this is a major problem with...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 08, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
I bought a kitchen aid gas range 4 monthes ago. The model no is kgss907sss. The oven takes more than 1 hour to preheat to 375F. Sometime it even can't reach the temperature forever.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | KitchenAid KGRS807S Gas Kitchen Range
The door is "stuck". I entered the self clean mode and forgot something in the oven so opened the oven after 3 seconds into the cycle, I cannot close the door now anymore and or cancel the self clean...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 01, 2010 | KitchenAid KGSS907SSS Gas Kitchen Range
Door locked after self clean
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
May 12, 2010 | KitchenAid KGSS907SSS Gas Kitchen Range
Door lock will not release after selfclean cycle is done
heatman101
Apr 06, 2010 | KitchenAid KGSS907SSS Gas Kitchen Range
After installing range the door will not open
if posible turn your unit off for 5 minutes should rest it self
Feb 09, 2010 | KitchenAid KGSS907SSS Gas Kitchen Range
Oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
Jul 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KGSS907SSS Gas Kitchen Range Logo
200 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Jacques Valiquette
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
