Question about Black & Decker Quick N Easy X320 Iron
How to open the iron quick and easy 320? - Black & Decker Quick N Easy X320 Iron
Adding water to my iron?
You tip it up and pour water slowly in the little funnel at the tip end.
Feb 29, 2016 | Black & Decker Quick N Easy X470 Iron
How do you put water in it?
The filler opening is at the very front. Set the iron on its heel, press the button above the filler opening, and pour in distilled water until the iron is full
Jan 15, 2013 | Black & Decker Quick N Easy S350 Iron
Handle loose
Just look around for a loose screws, and tighten the screws. Should be a quick easy fix.
Nov 13, 2012 | Tefal Pro Express GV 8120 Iron
Where can I refill the water??
Apr 11, 2012 | Black & Decker Quick N Easy X470 Iron
Black & Decker Quick/Easy X415 won't stay on
Like most consumer whitegoods nowadays, the cover is 'protected' by 'tamper-proof' or security bits screws that take may forms: you can get the a set of screw driver security bits at most hardware or electronic shops.
The power cord to your iron has one or more electrical lead that has just about broken off due to fatigue failure: it is a dangerous situation because of potential arcing so I would get it fixed it as soon as possible by a 'qualified' person: that said, there are only three wires to your iron and once you get the back cover off, you can easily find out where ths break is by just pulling hard on each wires. The break would normally be fairly close so you have the option of shortening the lead (which must otherwise also be in good condition ) to where the longest break is and rewiring the leads back in exactly the same screw terminals on the iron.
Please remeber that you are dealing with a potentially dangerous main voltage appliance and extreme care is required.
Hope it helps.
Feb 21, 2010 | Black & Decker Quick N Easy X415 Iron
My iron won't turn on and if it does turn on it will shut off within seconds. Can you help with this issue? Black and Decker x420
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 21, 2010 | Black & Decker Quick N Easy X420 Iron
How to open to get water inside
No need to open iron! You just unplug the iron. Hold the iron upright. Using a clean cup, pour water into the "open" WATER FILL HOLES just above or in front of the Temp. Select Dial. Watch the water window on the left. When water level reaches MAX, you are filled. Plug in and use. Refill as needed. Ref. - Page 8 in the instruction pamphlet.
Oct 18, 2009 | Black & Decker Quick N Easy X420 Iron
How to clean inside of Iron?
Unplug the iron! Allow iron to COOL completely!!! Wipe soleplate with damp soft cloth or damp soft sponge. NEVER use abrasives, cleansers, scouring pads that will scratch iron and cause discolorations. The iron has an Auto Clean Steam Valve feature that will prevent most mineral and lint build up everytime you turn the Temp. Select Dial to "0" after use. (Ref. - page 11 of the instruction pamphlet). If you have a really bad hard-water build up problem, use a commercial Steam Iron Cleaner and follow the instructions exactly! Repeat every 3-6 months and you should be fine. Good luck!
May 04, 2008 | Black & Decker Quick N Easy X420 Iron
Treatment of new iron
Before first use, remove any labels or stickers, on the body or soleplate of the iron. On first use only, iron over an old cotton cloth using steps 1 thru 5 below on setting 5 or above (and the SURGE button for models with that function) to remove any protective surface treatments. 1. Using a clean cup, pour water into one of the two openings in the Water Fill Hole until the level reaches the MAX mark on the Water Window (A). Refill as needed. 2. Ordinary tap water can be used for ironing. Do not use water processed through a home softening system. In extremely hard water areas, consider using distilled or demineralized water, however, use tap water the first time you use the iron and once a month thereafter to maintain steam performance.
Jan 01, 2006 | Black & Decker Quick N Easy X485 Iron
Black & Decker Quick N Easy X320 Iron Logo
51 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
