Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
All of a sudden my garage door opener is only allowing my garage door to open half way. The door has probably only been used a dozen times yearly since purchasing it 6 yrs ago . used it a lot this past month and it worked fine up until yesterday. Any suggestions?
    President:
  • 3,197 Answers
Check the door springs and the drive gear.
Posted on Nov 08, 2010
How do I make it stop at 6 inches open using my car remote?
You have to press the button on the remote 3 times allowing for the little delay that comes with remotes. the wall switch is easier because it is wired directly to the opener. you will also find it sometimes works easier if you start with the door all of the way down.
Jun 08, 2015 | Craftsman 1/2 HP CHain Drive Garage Door...
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
My garage door will only open half way. It appears to be getting stuck when it is opening.
If you haven't gotten your issue fixed yet... I had the same problem (stopped opening half way when using the remote, went down fine, could lift/close manually fine as well) and this happened on our first cold weather day of the year which was very telling. Anyhow, there are two gauges/dials on your garage door opener unit itself (above, where the light is) which controls how much torque/strength your door uses to open or shut through resistance. I turned mine up some and it now works fine; what likely happened was that the metal tracks or the wood frame condensed in the cold and was providing just enough resistance to stop it when opening - as they have a security device built in to stop if they meet any resistance. Hopefully this helps!
Oct 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have liftmaster garage door opener P/N 41A-5483-4. It worked normally. but all of sudden, when door closing, it reverses automatically at half way down, and garage door light bulb starts blicking 6...
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
LiftMaster Garage Door Opener Frequently Asked Questions
Jan 02, 2011 | liftmaster Chamberlain Garage Door Opener...
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you replace rack on liftmaster? Mine is stripped
why stripped again in only one year. is door balanced. lift half way and let go (Opener disconnected) and does door stay there? If it slams down, check springs.
Feb 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I open the garage door it only opens half way and then stops
Gears may be wearing out. Take of panel with light bul (4 screws) and look inside. See white stuff? That is your nylon gear that is worn out. Rebuild or replace,
Jan 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 hp craftsman garage door opener won't open when cold
I called Sears garage door customer service number due to the same issue. The test is to disengage the opener drive by pulling the emergency disengage handle, then open the door half way manually and then let it go. If it stays there it is a door/track/lub problem; if it drops down and closes its a garage door opener problem. Mine stayed open half way during this test so it was a door/track/lub problem. After using silicone spray on all tracks, rollers, and springs mine has been working great. Good luck.........
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
All garage door transmitter would not work
The lock is probably engaged. Look at the wall button, the green light is probably flashing. Hold down the lock button for 3 seconds and light should be solid. Your remotes should work now
Oct 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
277 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
