Question about SanDisk Sansa e250 MP3 Player
About your reply to my problem
Im the one with the messed up sansa , I read ur solution and there isnt a volume + button .. i raise the volume by moving the little blue circle clockwise ..
How can you fix the sansa ?
  • Mike Cheh
    Mike Cheh Jun 14, 2008
    Ok . I did what u said previosly about the music button ..
    After i did that the computer couldnt search for anything ..
    Now after i took it off the usb my sansa is just blank black
    What happend , where do i go from here ?
  • 8,596 Answers
Use forward instead of volume +
Posted on Jun 16, 2008
Sansa e200
There is one option, not really a fix, just a workaround. Try the player on a different computer computer and see if it is recognnised there. If it is, then use something like a pen drive to transfer music from the PC that doesnt recognise the device to another that does. Now you can transfer music using the WMPlayer sync service.
If your device is not being recognised on many computers, it looks like it is time to chuck it away. You can also try this first though..
1. Remove the player from the PC and switch it off.
2. Restart the computer.
3. Hold the +Volume button and connect to computer.
4. Keep the button pressed for at least 60 secs, and you should see the "Found New Hardware" balloon pop up, indicating that the device has been detected.
If even that fails, then I'm afraid your Sansa player has run its course, and you may need to purchase a new player...:(
Jun 27, 2008 | SanDisk Sansa e200 MP3 Player
My usb hook up
Try diff. USB port first
Go to hardware --> device manager and see if there is a yellow exclamation bu usb port - if there is, right click and update driver
otherwise:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 25, 2008 | SanDisk Sansa e250 MP3 Player
Sansa doesn't work
May have to substitute HOLD or REC for Volume +:
Jun 23, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 4Gb Wont let me add or delete songs anymore!
If the PC does not recognize the player, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa clip 2 gig computer doesnt find
This is the method that will force Windows to recognize the Sansa: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e280 recovery mode
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | SanDisk Sansa e260 MP3 Player
Not detecting the mp3 player
its probably just ur player has messed up, because everything else i plug in works with no problem
Apr 27, 2008 | Philips HDD082 MP3 Player
Sansa View screen is messed up
ok i just had the white screen issue after some squezzing thinking it might be something loose i randomly decided to turn it on wile holding the left button and to my surprise im greeted by the word SANSA and not a white screen. hope this can help someone
Apr 08, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Help
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Jan 04, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
