Question about D-Link DGL-4500 Wireless Router
Blue Power led Blinking. But nothing shows up on my D-link DGL-4500 Router's display. Blue Power led indicator keeps blinking
  • 2 more comments
  • warlord_igle Nov 06, 2010
    It didn't Fix the Problem. That is what I thought was wrong with it. I Posted it to see if it was a Flashing issue or to confirm that indeed it was the Router that was failing. Already had tried a different Power supply, but it had the same symptom. I openned the Router up
  • warlord_igle Nov 07, 2010
    Nope, their not on. the only light on (blinking) is the Power indicator light. Display is Black, No image Displayed.
  • warlord_igle Nov 09, 2010
    Yes I am sure no Lights lit up except the Blue Power Indicator Light.
    Thanks !!! I guess ill buy a new one.
  • 4,889 Answers
You mean the DSL and LAN lights are not on?
Posted on Nov 07, 2010
  • eagle338
    eagle338 Nov 07, 2010
    Are you sure the lan and your DSL cable are connected firmly? The LAN and DSL lights will only come on if these cables are connected to the router.
  • eagle338
    eagle338 Nov 09, 2010
    If that is the problem then the router's modulation circuits are damaged. You will have to choose between getting it repaired or getting it replaced. I suggest the second one coz its gonna work out lot cheaper. You can get a new router for as low as 50-75$.
  • 6,993 Answers
I think your router is having a power problem. The power of your router is defective and cannot effectively power the router, that's why its blinking. This problem may have occurred as a result of excess power entering into the router, irregular power supply or power surge.
Borrow an adapter from a friend and test it with the router. If the router does the same thing, turn it off, leave it for a while and try again.
If the above doesn't solve the problem, then it you will need to get a repairman to fix the router for you.
Fixing this type of problem requires technical experience.
Good luck.
Posted on Nov 06, 2010
Hello, My D-Link DGL-4500 router won't work properly. The wireless portion will not work. I know the Username & Password. But no device I have will connect to it wirelessly. It'll connect...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 03, 2011 | D-Link DGL-4500 Wireless Router
How do I get into the routers homepage to change some settings so I can run a wireless internet connection to my laptop while my Playstation is hard wired. I have DGL 4500
To get into the D-Link DGL 4500 router homepage, simply open an internet browser window and type in the following address:
http://192.168.0.1 and press Enter.
When the login window appears, set the user name to Admin and leave the password box empty.
Then, click Login to continue.
Here is the link to the PDF version of the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
Jul 29, 2011 | D-Link DGL-4500 Wireless Router
I just bought a D link dgl 4500 router and it works fine most of the time. Tonight and one other night before it will reset my wireless network almost every five minuets. I have reset both the modem and...
Make sure you have the latest firmware as this might help with your dropped connections. Also try to make a DHCP Reservation for each computer connected to your network (p. 32 in the User Manual), as that can also help prevent dropped connections.
Download the latest firmware ver. 1.23NA to your local computer. Connect your DGL-4500 router via a wired connection (ethernet) to your computer and install the firmware update following instructions in the user manual.
Firmware link:
ftp://ftp.dlink.com/Gateway/dgl4500/firmware/dgl4500_FW_123NA.zip
Here is the PDF link to the User Manual:
Feb 23, 2011 | D-Link DGL-4500 Wireless Router
I have a D-Link DGL 4500 wireless router. I have
If you don't see any devices connected in the DHCP client list on the router interface even when you are sure of the devices being connected, only a firmware update or a re-flashing of firmware can help. You can find the latest firmware available on the d-link support site. You can verify the model and version numbers and download the corresponding firmware. This is only fix.
Feb 05, 2010 | D-Link DGL-4500 Wireless Router
I am trying to get my laptop connected wirelessly to my dgl-4500 router. It keeps saying connection time out?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 11, 2010 | D-Link DGL-4500 Wireless Router
My Dgl-4500 shows wrong date. How can I change it?
Download the official manual (in PDF format) here: ftp://ftp.dlink.com/Gateway/dgl4500/Manual/dgl4500_manual_11.zip
And refer to page 15 (time setup). In short, login to the D-link web-interface, choose 'Tools' and then 'Time', adjust it and press the 'Save Settings' button ...
Aug 27, 2009 | D-Link DGL-4500 Wireless Router
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
Problems connecting to DGL-4500
This can be a firmware problem so upgrading the firmware of the router should fix this issue on it, so I advice you to upgrade to the latest firmware of your router, you can get it from Dlink web site...
Oct 19, 2008 | D-Link DGL-4500 Wireless Router
D-Link DGL-4500 Wireless Router Logo
138 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
