Question about DeLonghi Caffe Nero BCO264 Espresso & Coffee Maker
I have a BCO 264B. It turns on but doesn't make coffee nor does the warmer plate heat. Is there any way to fix it?
3 Suggested Answers
  • 3 Answers
SOURCE: Cafe Nero turns on, but will not make coffee
I understand this unit has a fuse inside that blows out. I cannot confirm this as I need to find a special screwdriver to open it. I'll post back my results if possible.
Posted on Apr 04, 2009
SOURCE: coffee maker wont start
I had the exact same problem with my DeLonghi Caffe Verona Expresso Machine (very old) and I replaced the thermal fuse and Bingo....it works fine! I did call DeLonghi and the tech told me the Thermal Fuse is the most common problem of no power. (providing your unit is plugged in and the receptacle works) In my unit the fuse is on top (only one) and it did have a plastic sleeve over it. The fuse was bought at Radio Shack for 1.99 and I had to solder it on because I forgot to get the little crimp ends from the Radio Shack guy. oops If I can do it...anybody can. (55 year old Grandma)
Posted on Apr 08, 2011
Make the coffe portion work again
This category is for printers and copiers, please submit your problem in the appropiate catergory.
Sep 21, 2014 | DeLonghi Cafe Nero BCO-264B Coffee Maker...
Lifetime of BCO 130
when did you last descale the unit?
also running Milton fluid to the correct strength through with out heating may kill any bugs
Dec 06, 2013 | DeLonghi Coffee Makers & Espresso Machines
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
Bottom heat plate is not hot enough
Warmer element may have dropped.Remove 3 screws and check.There are two nuts that fasten warmer to plate.
Jan 04, 2011 | Bunn VPR Coffee Maker
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
Jul 29, 2010 | DeLonghi BCO120T Programmable Espresso /...
Water wont heat. Warmer has no heat but light is on
Hello, One of the wires soldered to the underside of the warming plate had fell off due to poor soldering.The warming plate and the warning light are connected together with piggy back connectors so that is why the light is on even when the warmer is cold. Bye
Jul 03, 2010 | GE 106591 Coffee Maker
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
DeLonghi Caffe Nero BCO264 Espresso & Coffee Maker Logo
27 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
