Question about Tappan Ovens
I have a tappan wall oven with model number tgb500cfb1 and I do not know how to turn off the oven timer
SOURCE: problem with tappan wall mounted oven
yes, the problem is fixed thanks to repairclinic.com. those guys are awesome and there is no fee for their help. the repair parts are cheaper than anywhere else i've checked and the tech support is second to none.
Posted on Oct 12, 2008
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
  • 360 Answers
SOURCE: F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 09, 2009
  • 408 Answers
SOURCE: Oven will not turn on
You need to replace the igniters for the top or the ignition filiment if it is the bottom.  You can get these at any appliance center.
Posted on Mar 12, 2009
SOURCE: Wall oven not working at all
mine is broken too. exact same problem. same oven. email me if you fixed yours, please!!! quinnalisen@comcast.net
Posted on Apr 06, 2010
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
Seal on Tappan wall oven came off, what to do?
Hey friend, I appreciate your post!
I understand that seal on your Tappan wall oven has come off. In order to provide you additional information regarding the seal I would need your model number and serial number. You can locate the serial tag (which has your model number listed) on the front of the oven on the left side. With that information I could provide you additional assistance. I look forward to your response. -Matt
Aug 03, 2014 | Tappan Ovens
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
I need parts for an older tappan wall oven..model Z12-1449-00 ...a thermostat and thermostat knob
It's going to be hard to look up the old model numbers, but there is a number on the old thermostat that might help.I may possibly have one but have no way to look up the specific model.
Jan 21, 2010 | Ovens
Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Sep 08, 2009 | Tappan Ovens
Tappan electric wall-oven always says off ????
Check that one of the two hot wires is not losing power due to bad connection. This needs to be checked clear from the breaker to the terminal in the oven. Loss of one side of the 240 volts may still allow the clock to work as long as no other element is on.
OFTEN the connection of to the plug in the wall is bad... IT IS ALSO a fire hazard.
REMEMBER to turn off the breakers when working on this!
Aug 28, 2009 | Tappan 30IN ELEC IGNa Oven
Tappan wall ovens doors nneds replaceing. This is a gas wall oven. I notice the spring one one side came ouy. Any solution.s
Hi, With the model #, I could get you the info on the part# and how to change them springs and maybe=y hinges.
Please let me know
Thanks
Vic
May 11, 2009 | Ovens
Manual for Tappan Wall oven
I just replaced my springs, the springs are the same as okeefe and merit
i have probably the same oven as you . Antiquegasstoves.com They have many pictures of all the springs there! mike summers
Apr 05, 2009 | Ovens
clarkco
Feb 09, 2009 | Tappan Ovens
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
