Question about Canon ZR85 Mini DV Digital Camcorder
Cassete not getting inserted.[message comes as remove cassete]
  • 21 Answers
Does this happen with all cassets???
If So then....
1. try using a head cleaner casset.
2. connect the cam to your p.c. and check it for viruses.
Posted on Nov 06, 2010
Any idea how to fix it? Is it the sensor or something else?
Open totally the cassete look for paper jam inside that might cover the sensor.
Remove cassete and look for black plastic actuator located on top of paper when cassete is inserted, it might be broken.
If all are ok , press as follow to reset the malfunction [off] while pressing [ Utility/Counter] turn [On] wait till the display appear then [trouble reset] it will appear OK on screen turn OFF/ON main power.
Aug 17, 2015 | Konica Minolta bizhub C250 All-In-One...
I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
Dec 17, 2010 | Canon Office Equipment & Supplies
Hello...i m using a sony DCR-HC48E....from 2 yaers....very good condition still...not much used even.... Oneday i just ejected its cassete in a proper manner...and than afterwards i was no way able to...
Your continual use of multiple full stops makes it difficult to comprehend your query - as I understand it, you have broken your camcorder. Your choices are to get it repaired or to replace it. BTW, demanding help 'immediately' is both impolite and uncouth - we deserve to be treated with respect.
May 05, 2017 | Sony DCR-HC18E Mini DV Digital Camcorder
The Casset is rejecting back
I got the solution from your net only.Thanks it is wotking presently.you have to do simply take out the cassete and keepp the cassete door open.And then take both the battery out i,e one main battery and another small battery and leave camera in this psoition for two hrs and tehn place back battery in its position and then load cassete .It will work.I have tested it.Thanks a lot.
BK PRASAD
Apr 19, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
REINSERT THE CASSEETE
Me also getting the same problem.. but some times it is getting okk...  what i m doing is, put the casset while pushing the cassete hold little bit down.. i think it is due to the improper position of the cassete holder...
Jul 20, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
New casset insertion not displaying any image on the screen
JUST BUY A CLEANING CASSETTE AND PLAY TWO OR THREE TIMES AND PLAY YOUR RECORDED CASSTTE.IT WILL BE VERY CLEAR.
REGARDS
SANKAR
Oct 24, 2007 | JVC GR-D370 Mini DV Digital Camcorder
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
Canon ZR85 Mini DV Digital Camcorder Logo
88 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
