Question about GE JVM2070 Microwave Oven
The switch for light and vent is broken. How do I remove panel to access?
Here's the link to the solution-NB see solution 2, solution 1 is vague and almost useless: http://www.fixya.com/support/t125749-buttons_light_fan
Posted on Dec 15, 2010
I have a GE Space maker 2.0 model JVM2070SK02 that has three buttons on the lower right vent, boost and light. The light button is pushed up into the microwave. I think there must be a spring behind the...
Remove the top grill and on top of the control panel is (1) screw, remove that and gently tap up the control panel to release the panel from the microwave front cabinet. Now as I researched this model, the buttons are part of the panel and are attached to the panel directly. Up may want to replace the microwave as the price is high to replace the panel. Part number is WB07X10972, Good Luck and be safe and unplug this unit before removing this panel.
Nov 16, 2014 | Microwave Ovens
The part that holds the door switches inside the oven is broken; can the part be replaced
Yes this can be stuck using a instant glue if the broken pieces can be found. Usually this needs to hold the switch and lock in alignment.
So try this out , you can remove the front panel and get access to this assembly.
Jan 21, 2013 | Microwave Ovens
Vent, Boost, Light buttons pushed in - not working
They may be available as a unit--two or more and will either be melted into place or secured with screws etc.
May not be a easy part to find or see if it is even sold as a part.
Dec 12, 2012 | GE Microwave Ovens
I replaced the light bulbs but they still do not come on and the vent fan will not come on either?
the fan and the surface lights are run through the control via the touch pad. if you tried to replace the bulbs without unplugging the unit 1st you probably shorted the board. this can be checked by lowering the touch control panel by first removing the vent above it to access the panel screw. at this point you can observe the control for burn marks
May 17, 2009 | Hotpoint RVM1325WW Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Fan and light buttons pushed in, how do i install new buttons.
I just fixed mine. Same problem.
  1. remove the top vent (like replacing filter) w/ 2 or 3 screws on the top of the unit
  2. Remove the one screw on the top of the clock/control unit.
  3. Remove the clock/control panel by sliding up then out
  4. See circuit board at the bottom for the 3 switches. Hopefully it just popped out of place.
  5. pop it back into place and re-assemble
  6. if it's broken, you'll have to find the replacement part here: http://www.geappliances.com/service_and_support/
  7. If the actual buttons (black plastic) are broken, you have to replace the whole plastic housing for the electronics. Probably a big project and/or you'd replace the whole bit for hundreds of dollars, but even still, it's a pop-out, pop-in.
Good luck,
-tj
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp 1470 over-the-range microwave - no power on panel
Did you unplug any wires when you took it apart?
Otherwise, I would think one or more of the connectors got unplugged when you removed the control panel.
Another thing that can happen on these models is a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under thebottom edge of the switch. It's usually the top door switch.
You can find the wiring diagram at our site here.
After you look into this, if you still need help, please write back with more details.
Oct 12, 2008 | Sharp R-1610 Microwave Oven
Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Apr 30, 2008 | Whirlpool GH7145XF Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
GE JVM2070 Microwave Oven Logo
108 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
