Question about Dell Vostro 200 PC Desktop
The fan keeps running but nothing powers on - Dell Vostro 200 PC Desktop
  • 51 Answers
First check all your cords, to be sure that everything is connected properly. If all checks out, you may need to check you on/off button to be sure that it has not went out.
Posted on Nov 06, 2010
Fans keep running after bed shut off
The fans will run until the temperature has been reduced. Just because you shut it off doesn't mean it gets immediately cold. It's just like the fan on a car that keeps running after the car stops.
Jan 03, 2015 | Wolff Sunvision Pro 24S Tanning Bed
Why does fan motor keep running after engine is shut off
This is normal and there should even be a warning label near the fan shroud. It is cooling the radiator and as long as it eventually does go off there is nothing to worry about.
Jul 21, 2014 | 1999 Dodge Caravan
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
My imedia b2217 will not boot. Is the motherboard dead? Whenever I switch on the computer nothing happens. No lights, no fans, nothing at all. I have replaced the power supply but still nothing
Hi i'm Basti,
How bout the fan for your power supply, is it running? Try to retrace the cables to motherboard and make sure its tight. Change or use another power supply if possible.
Keep me posted. Hope this helps.
Feb 25, 2011 | Packard Bell iMedia SL 9553 (P660401806)...
Notebook fan
Yes most likely as otherwise you would not have been advised to shut down. The processor get red hot is not cooled continuously by the cooler fan. And heat of all sorts is bad for the health of the processor and other components. What I would suggest is to use a Cooling PAD available on Ebay. This is nothing but a tray that has three USB powered fans that keep dissipating the heat with these three fans all the time the laptop is running. Very helpful. Although you spend some money on it, but in the long run it works wonders.
Nov 30, 2009 | Televison & Video
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
When I press power button, only power button is lit green solid and nothing else happens...nothing on the screen...all black. No sound codes. Tried external monitor...nothing. CPU fan keeps running....
yes its motherboard. GPU has failed. Most likely you'll need to get your motherboard Reballed or Reflowed. I have found some reasonable business partners that do this service through ebay. usually runs 80-140 to get fixed. good luck!
Ruben
Jul 18, 2009 | Acer Aspire 5100 Notebook
Problems with Gigabyte GA-8I845GVM-RZ Motherboard
nothing but the fans run.the hard drive will run if i unplug the ribon.I changed the power supply and still not working
Mar 08, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Air conditioner/furnace squirrel cage fan remains running when th
Ensure you don't have a short in your therm wires. Disconnect them, if the furnace continues to run, you have a lockout problem at your furnace. When the motor on the fan fails, it wont run. Check for led codes on the control board. If you don't have led codes, turn off the power to the furnace at the breaker, and watch the unit. If nothing happens, connect the thermostat. If nothing happens still call for heat. Let the therm run through it's cycle, and if the bower runs continuous again, let me know we can walk through that situation.
Dec 05, 2008 | Ruud Central System Air Conditioner
Dell Vostro 200 PC Desktop Logo
79 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
