Sharp Aquos LC-37D62U Power on problem When You plug in power cord to outlet Power light and opc Green Lights Flash On Together Then Power light Blinks by itself. It does this Over and over repeatedly Even after I push power button to turn on
  • Rey Garza Nov 13, 2010
    Power light and opc blink once together then opc blinks once by itself . It does this over and over.........power light opc 1, then opc 1, power light opc 1, then opc 1, power light opc 1, then opc 1
  • 19,396 Answers
Re:When You plug in power cord to outletPower light and opc Green Lights Flash On TogetherThen Power light Blinks by itself.
I have done several Aquos in real life, and I should be able to help.
That is protect mode (forced standby), that indicates that an internal fault has ocurred.
Sharp Aquos may not give any error (blinking) code when this happens. In that case the TV must be taken apart and tested by a technician.
If there is a code error, that is given by the way the power light flashes, in that case let me know if there is a standard pattern, and let me know how many times the power light flashes. The current description does not fit any code.
Thanks.
Posted on Nov 06, 2010
  • Ginko
    Ginko Nov 06, 2010
    I understood that OPC light flashes once. I need to know how many times power light flashes.
    If for example the power LED flashes twice and OPC LED flashes once, that means that there is wrong voltage in the 10V circuit. In that case the technician will focus on that problem.
    I must warn you that even knowing the error code, the TV must be tested and repaired by a technician. An LCD TV cannot be repaired without multimeter and iron in hands. At least without testing there is a big risk of buying the wrong expensive part.
  • Ginko
    Ginko Nov 13, 2010
    Hi.
    That means that the power LED flashes once, and that OPC flashes twice. Sharp Aquos codes repeat cyclically.
    Problem detected is a power error. In most of the cases this mean a faulty PSU. The PSU must be tested and fixed rather than being replaced, as the main controller board may also be responsible.
    If the OPC led flashes twice cyclically, then the problem is on the 3.3V line in the PSU. Testing is carried jumping the control line for 3.3V and checking if there is voltage in there.Testing must be done by a technician. Repairing an Aquos PSU ranges between $150 and around $250, depending on part price. Cost may go up if instead of PSU the problem is digital board.
    Here relevant part of service table:
    Here new part:
    LC610-4001CC
    or:
    LC610-4001CC
    (last one is not listed for this model, but it is same part)
    Here used parts:
    Sharp used parts
    Sharp LC-37D62U Power Supply @
    Regards.
    Ginko.
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
OPC and Power green lights blink twice, tv will not turn on.
follow this instruction and fix it. God bless you
    • 1
      Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2
      Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • Sponsored Links
    • 3
      Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4
      Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Read more: http://www.ehow.com/how_7308433_flat-screen-tv-won_t-turn.html#ixzz2ZROWyhSB
Jul 18, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Aquos has the power light and OPC light flasing but nothing works
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Jan 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
1,269 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
