Question about Little Giant Water Heaters
When i started the pump it ran for mabe 15 minutes and the breaker kicked out. these are the conditions> Im using a 30 amp breaker gfci- I found a leak in the piping between the pump and the intake side of the heater. The thermostat is set to hi heat. I would like to know what the water should feel like as it come out of the heayer
SOURCE:
muttandjeff
  • 359 Answers
SOURCE: Water heater ground
run to breaker panel or drive a 8ft ground rod and connect to it the water line is no longer acceptable as the public utility's are using pvc for gas and water now and this is no longer a practice you could use the ground rod that is already installed on your service and use connector , but something you might do well to check is to make sure in the process of installing the plastic pipes the ground going to the panel was not also disrupted if so you will need to install 2 8ft ground rods at least 6 ft apart and daisey chain together with proper size ground wire . # 4 solid for 200 amp and # 6 solid for 100 amp service , I would make sure the panel ground is solid very important for safety ,, let me know if i can further assist
Posted on Feb 07, 2009
  • 234 Answers
SOURCE: Water heater trip circuit breaker
I would say you have a bad element in the bottom.If the water is cold and heat until the top thermostat reach it tempture,then switch the bottom element and then the breaker trip.So replace the bottom element.
Posted on Mar 15, 2009
  • 252 Answers
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
Posted on Oct 23, 2009
SOURCE: Paloma PTG 74PV N1 Tankless Water Heater - stops heating
I had this problem back in April '09. I called the toll free customer support number in the manual. The lady said that that code indicated a communication problem between the panel and the main unit. She said they would send a new main circuit board and controller. In the meantime, the work around is to unplug the power, disconnect the panel and power back on. You will have hot water but no temperature adjustment. I had the new parts in about 2 days (shipped to Hawaii) and installed them. No problems for 9 months now. :-)
Posted on Jan 05, 2010
motor1258
  • 6674 Answers
SOURCE: atwood water heater runs for two minutes and shuts
If you have the little thermo cut off in the circuit to thermostat, (little resistor inside small plastic tube) try removing it from the circuit. Just pull the wires at each end and attach directly to thermostat where it was before. If it works now, you found the problem, if not, get back to me.
Posted on May 09, 2010
What is the maximum size breaker for the powerstar tankless water heater 45-557701
Check the name plate on the heater. You should see the amperage rating. For example, if it is rated at 30 amps, then you will need a 30 amp breaker. Do not use a larger rated breaker, that will defeat the purpose of it's safety use.
Apr 13, 2016 | Water Water Heaters
All the parts are working 100%,but jacuzzi trips the earth leakage after 2 hours
If your GFCI is tripping, it could be due to a bad heater element, pump, blower or ozonator. To determine which component is causing the problem, unplug the components one at a time and turn the breaker on. If the breaker does not trip after unplugging the pump, ozonator or blow, you've found the problem and you can now replace that component. If you've unplugged all three components and the breaker still trips, it's likely the heater element. Hiring a technician or replacing the heater is the next best course of action.
Apr 06, 2016 | Jacuzzi Water Heaters
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
E1f50rd045v
For residential water heater, 30 amp is best... but must have 10 gauge wire.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Color-codewire.html
If you have 12 gauge wire, then use 20 amp breaker and install 3800 watt elements in place of 4500 watt elements
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Add a comment and say which size wire you have
May 16, 2013 | Water Heaters
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Electric shower just installed cuts out at fusebox after being on for about a minute
10-20-12
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Oct 18, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
Titan SCR4 tankless water heater. Breaker on water heater itself keeps kicking. Not in breaker box. I have 2 double breakers, 50 amps each in box, no problem there. On the water heater there are 2...
Breaker trips when heat on wire exceeds amp rating, or when breaker is bad.
Most breaker are slow acting, and do not trip immediately.
Shorted elect could cause problem.
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
Oct 15, 2017 | Water Heaters
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
Can i replace 4500watt elements with 5500watt on a 606 model
1) Manufacturer's warranty will be voided, and I've never seen recommendation that suggests better heating or saving money from replacing 4500W with different wattage element.
2) That being said, you have 240V water heater.
4500Watts divided by 240 = 18.75 amps
5500Watts divided by 240 = 23 amps
20 amp circuit breaker with 12 gauge wire is rated for 80% of load = 16amps
30 amp circuit breaker with 10 gauge wire is rated for 80% of load = 24amps.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
3) You can use 5500Watt element if you have 30 amp breaker and 10 gauge wire.
Feb 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
Top Little Giant Water Heaters Experts
Gene Haynes
David Spradling
David Spradling
Are you a Little Giant Water Heater Expert? Answer questions, earn points and help others
