Question about Sanyo PLC-XP100L Projector
How do you reset the filter warning light after replacing the filter on a Sanyo XP100 projector
SOURCE: Sanyo Pro xtra projector - warning light
Easy Fix, there are two air filters that need to be cleaned.
Posted on May 14, 2008
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Posted on Mar 07, 2008
Marrie
  • 563 Answers
SOURCE: Sanyo Projector
Hi there
First make sure that your lamp timer & filter timer ( if available ) is reset.
If the problem still occurs , take a flashlight and check if your fans is running a normal rate when the unit is switched on.
It's easy to spot. If you can't spot it with the eye - take a thin piece of paper and touch the fans slighly - you'll hear the difference immediately - in wich case it woul need replacement
Posted on Mar 26, 2008
  • 105 Answers
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
Marrie
  • 563 Answers
SOURCE: lamp replacement
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
Posted on Sep 26, 2008
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
Suddenly turn off blue screen
The problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so, you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Nov 16, 2013 | Sanyo PLC-XL51 Projector
Sanyo plc xp100 - all indicator lights are flashing when turned on
I have only experienced all the indicators flashing after 3mins of powering up and then suddenly shutting down. I have not yet experienced the indicators flashing straight after turning on.
I think the problem for me was that the filter wasn't seated firmly enough in the filter compartment. I was able to stop the indicators flashing by turning off the power at the power point, removing and reinstalling the filter, making sure that it fit firmly and tightly in the compartment. Then I turn the power back on. I believe that sometimes if the filter isn't set in the compartment tightly enough the projector will think that no filter has been installed and will automatically shut down after 3 mins.
You also need to make sure that the filter has not run out of scroll. to test this, push down the small, white spool on the left whilst pushing down and turning the large geared spool on the right anticlockwise. If the filter continues to scroll you can still use it. If not, the filter has reached the end of the spool needs to be replaced.
May 09, 2012 | Sanyo PLC-XP100L Projector
I have a Sanyo PLV-Z2000 projector. The screen had a filter warning and we cleaned the filter, but now the screen is just blue and won't omit any image. It worked to reset the filter timer before, but...
the excessive heat and lack of airflow may have caused another problem. can you get into the menu? if you can, try resetting the settings to factory default.
Dec 29, 2009 | Sanyo PLV-Z2000 Projector
Can't get the lamp light to turn off on my sanyo xp57 projector. replaced the lamp and the lamp warning light won't shut off.
Go into the menu and look for the settings icon. Under the setting icon you should see a lamp counter reset button. Select that and the lamp replacement light will go out.
Jul 30, 2009 | Sanyo PLC-XP57L LCD Projector
Temp warning
Clear the air flow and replace or clean air filters. that will solve.
Nov 02, 2008 | Sanyo PLC XF45 Multimedia Projector
Replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Jul 21, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo Projector
Hi there
Mar 26, 2008 | Sanyo PLV 70 Multimedia Projector
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC-XP100L Projector Logo
473 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
