Lakewood 792/JR Utility Heater Logo
Posted on Nov 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit stays running can not turn down themostat
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Nov 06, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
6810
Points
149
You will need to contact the dealer for that. Of course, if you still have the reciept, then i recommend taking it back to the store.
4helpful
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
I have a Dometic A/C unit that is not functioning. The furnace won't fire up as well. Have checked all fuses etc, and installed a new thermostat and controller in the A/C unit last night ... still...
When you say your fan runs do you mean on the furnace or the outside unit? Double ck your themostat wires if you have a volt/ohm meter ck for 24 v at the contactor in the ouside ac unit. On most A/C units you can manually push the contactor in to make it contact be carefull 220v use an screwdriver to do this and push only on the plastic center if the unit kicks on your themostat/wires/or contactor is bad my bets on the wires. good luck
My trane xt300 themostat is stuck on wake mode. Cannot
Press run prgm. If unit stays in Wake Mode the thermostat must be replaced.
1helpful
The fridge area is staying around 32-33 degrees. the setting is set to 38. the water reservior is frozen so no water.despenses ice maker is ok. What may be the cause
The thermostat contols the run time of the unit.If the unit is running way below the set temp most likely the themostat is bad.Sometimes on old refers, they can lose a small amount of freeon and still get cold. But, not completely enough to trigger the thermostat to shut off.If your refer is less than 7 years old I would suspect the thermostat.
1helpful
Our rheem gas pack running on propane will turn not always ignite
have you cleaned the flame sensor located on the
far left side of the burners?. Watch it go through the
cycles.
Igniter glows, gas valve turns on and gas ignites. If it gets that far and shuts down, it sounds like a dirty
flame sensor,clean it with sand paper.
2helpful
2answers
I have a Lasko Model 5532 electric heater. It has suddenly started shutting off often. I run it through the reset procedure (unplug 5-10 minutes, then restart) and that gets it going again, but then it...
All of these space heaters have thermal protection units in them. They are safety that shuts the unit down if it starts to overheat.If your fan is operating, then it sounds like the thermal protection circuit is faulty, and you'll need to contact Lasko for a replacement. These units do not have parts that can be purchased due to their UL compliance. Check the fan though, it might be obstructed. I have seen that more than once....Rob
Mastercool pump runs when themostat is off.
Check the compressor relay (in the outside unit) Most likely it's stuck.
Heater blower doesn't work
it sounds like the themostat has stuck open. i would change the themostat and also make sure that there is no debri caught in the grill . make sure the plow is not blocking air flow
1helpful
2answers
Intermittent heater control Marvin 2060
On Monday, 1/21/08, I returned the Marvin 2060 heater to the store I purchased in 02/07 since the freeze guard stop working. The owner left me a voice message at home and said he after doing some research, he discovered Marvin went out of business in 12/07.
And the heater is no longer covered under the warranty. The owner gave me a telephone number, 800.326.3690 which carry the parts for Marvin Heater. I have not called the number since I am looking for another heater with the freeze guard feature since it something I need quickly.
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul Carew
Jay Finke
Jay Finke
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
