Question about Dyna-Glo D-E39 (LP) Wall Mounted Panel Heater
I have a wall propane Dyno-Go 30,000 BTU five bricks\r\nModel RMI 80 LPT Serial 02-01628 I need a manuel so i can turn down the pilot where can i find one and the cost.
  • 51 Answers
Go to the Dyno-Go website, to see if they have a mauel available there.
Also you can type in the brand name in the search engine, and hopefully download a free one. If not, then check ebay for the maual
Posted on Nov 06, 2010
I am looking at a Vanguard VP20BTB propane heater but I need the dimensions to make sure I can use it. Does anyone know the dimensions?
Oct 13, 2018 | Vanguard Heating & Cooling
I have a two year old Redstone 30,000 BTU propane wall heater. There is a lot of dust behind the unit. After running for awhile on the 2 setting, it shuts down and the pilot is extinguished.
If it is a wall unit, it has an over temp safety switch which is most likely tripping from dust preventing proper airflow across it . A good cleaning should cure this.
Feb 04, 2015 | Heating & Cooling
Empire wall furnace pushing down the pilot button trying to light the pilot found too much gas flowing
Is the button on the gas valve or a red button in the line to the pilot assembly? If its in the line, there is a regulator upstream of the button. If the gas is coming from the gas valve, there is a small screw covered hole in line with the pilot line in the gas valve. If neither of these apply, you may need to replace the orifice in the pilot assembly. Let me know how it goes.
Nov 19, 2013 | Empire Comfort Systems Direct-Vent Wall...
Coleman direct vent forced air furnace modem # 7956C856 56,000 btu/hr input 46,000 Btu/hr output Serial# 920672512 I just moved into a mobile home and complained to my landlord that the heat wasn't...
Okay turn the power off at the wall switch first . Light the pilot hold button down for say 1 min pilot should light ?
If it has turn to on position turn power back on and turn up thermostat should light .
May 12, 2017 | Heating & Cooling
I have a Dyna-Glo RMC-50LPT propane heater that is about 5 years old and I can't get rid of the yellow flames when it operates. I have tried: - removing the heater and blowing everything out with a...
Dennis easy fix what is your out going gas you will need a manometer to verify it accurately or adjust your gas valve til your blue flames are gone. Let me know what you find!
Dec 16, 2010 | Heating & Cooling
My heater won't stay running
if you get heat when it runs and then it shuts downs you need to clean your flame rod or replace the thermocouple if its a pilot lit furnace
Feb 06, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Pilot will not light- rmi-80ngt-30,000 btu
if it wil light and wont stay lit replace your thermal coupling
Jan 23, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
Heater will not stay lit after releasing button
Make sure your thermocouple tip is in the pilot flame and the other end is snuggly screwed into the control. Clean the pilot if not heating thermocouple. If pilot is heating tip thermocouple and it still goes out after holding the button down for 2 minutes, then your thermocouple is likely bad.
Jan 22, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Wall mount propane heater ignites, but won't stay lit
I have a Reddyheat IWH16NLTD with this problem. When the heater fan turns on it blows the pilot light slightly up and away from the thermocouple causing the safety valve to close after the ceramic cools down. The manual says that low gas line pressure can cause the flame to rise too far from the thermocouple causing this problem, so either it is a problem with gas pressure, or it is an assembly plant problem.
Jan 10, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Dyna-Glo D-E39 (LP) Wall Mounted Panel Heater Logo
339 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Marvin
Marvin
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
