Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 All-In-One Error 0x883d55f8 - HP OfficeJet 7410 All-In-One InkJet Printer
HP Officejet 7410 All-in-One Blue screen error message 00000020
I did everything you said, even the angry part lol and still nothing. Sigh...well, I've been wanting an air printer anyway :D
Oct 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Fatal error with HP officeJet 7410
these machines are uneconomical to have repaired.
Sorry, you probably have a BAD SCANNER ASSEMBLY.
Feb 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP officejet 7410 error message 223
Hi pilchuck3,
please click on following link and which will help to how to access the ECM (Error Correction Mode), Please turned it off and i thing your issue should be resolved,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00313088&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Dec 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 Printer Error
Is the printer highlighted? Is it set as a default printer?
Oct 16, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP oj 7410 allinone
Download latest drivers from HP site. The disk may be bad.
Apr 02, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
