Question about Dell E173FP 17" LCD Monitor
My monitor is stuck in power save mode, how do i unlock it?
SOURCE: Stuck in power save mode
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
Posted on Apr 28, 2008
SOURCE: sleep mode on a dell monitor
Hold down the function key on your keyboard (lower left hand side of your keyboard between the control key and the windows key) and the F8 key simultaneously. This cycles through all monitor set up modes.
Posted on Feb 15, 2009
Bat1956
  • 585 Answers
SOURCE: dell monitor goes into power save mode immediately
The burners may have nothing at all to do with this. Try the monitor on another computer (a laptop will do) if you have one. If the problem perists with the monitor, then the moniitor has failed. If the monitor works on another computer, or you do not have another to try, then start the computer and tap the F-8 key to boot to safe mode. If that gets you a display, then fix the display settings, also check the device manager for any signs of hardware trouble, and make any corrections that may be needed, and reboot. If safe mode does not get you a display, try disconnecting the new hardware. If still no joy, I'd say it's the monitor.
Posted on Feb 20, 2010
  • 732 Answers
SOURCE: stuck in power save mode
stlmeuzyk, Internal "switch-mode-power-supply"/"ccfl-inverter-supply" will probably need to be refurbished (repaired). Use Dell warranty first if valid option! Try monitor on different pc or verify your pc is working properly with old, but known-good monitor. If your E228WFP unit is still not working then you or qualified electronics technician will need to tear-down monitor to evaluate and repair the ac to dc power supply printed circuit board. Before you do anything read my fixya profile to learn flashlight test that every ccfl back-lit lcd monitor owner should know how to do and interpret the results of test. The basic design and operation of your E228WFP isn't any different than any other brand!!! Read the older solutions in my profile and follow the links you find there. Then do additional comment if need more info. Good luck with the repair. 12fixlouie
Posted on Mar 26, 2010
supertech6
  • 513 Answers
SOURCE: Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Posted on Mar 30, 2010
Monitor went into power save mode and would not come back on
If your monitor is stuck in power save mode then first of all check all the power cables connected to monitor and your CPU.
After checking the connectors start the monitor if it does not come back from power save mode then lets move towards to second step.
2 . First unplug all the power cables to avoid power shock. After unplugging the power cables open the cabinet and look for the video card on *********** board.
Take the video card out and clean it with a normal eraser.Rub it on the golden pins and clean it.
Place it again at its place.
Close the cabinet and then start your monitor and your problem will be fixed.
Thanks for using Fixya.
Nov 13, 2010 | Computers & Internet
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
My flatron 1920P monitor is in power saving mode. How do I get it out of power saving mode?
It may stuck in the standby mode because it is not seeing the signal feeding it or there is problem in the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 29, 2009 | LG L1920P 19" LCD Monitor
My Dell monitor is stuck in Power Save Mode. Any
The monitor is not receiving signal from the computer. Verify the computer is on and the monitor input is set to the correct mode or auto. Try another monitor if possible.
Aug 10, 2009 | Computers & Internet
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Sleep mode on a dell monitor
Nov 22, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
My ibm desk top is stuck in power save mode monitor won't work
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Nov 20, 2008 | Computers & Internet
My desktop pc has gone into power save mode
Turn the whole pc off then back on. If the LCD stays in power save then I would try a diffrent monitor on the PC. If that fixes it the the monitor is probably stuck in power save. Check www.lcdrpair.us for parts and instructions.
May 28, 2008 | Dell E173FP 17" LCD Monitor
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
349 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
