Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
My ws-55315 as soon as i push the turn on botton it clicks and turns off. the tv doesn't even light up
  • Anonymous Jun 23, 2008
    Having the same problem.
  • 927 Answers
Good Day afsho;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C.
good luck, big irish.
Posted on Jul 02, 2008
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Wont turn on, turn power on and tv turns off and you hear click.
DO THE SELF CHECK WHEN POWER LIGHT GOES OFF.
On front of set press and hold both the menu and input buttons for at least 5 seconds and release both, power light will blink a two digit error code like 2 blinks, 2 blinks, and pause and repeat several times.
Let me know error code and I will tell you what it means.
SD TECH
Dec 07, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Hi my tv is the ws-55315 and i turn the tv on the light comes on for a second(the power light) and the tv shuts off is that the bulb i dont know?and how do i fix it
WHEN the power light goes off on front of set, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks, a pause and it will repeat code several times.
This is self check and will narrow down what is wrong with your set.
Let me know what code you find and I will tell you what it means.
SD TECH
Nov 06, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Ws-55315, screen turned to fuzz
If it was the lamp there should be nothing. press the menu button if the menu does not come up the issue is with the tv. If the menu does come up try a second source a dvd player or game system. If the issue is only with the original source than the original source needs to be replaced.
May 05, 2010 | Mitsubishi WS-55315 55" Rear Projection...
T v turns on and off
if you hear a constant clicking sound that means that there is a component shorted in the high voltage circuit.. call your local tv guy for verification if any are still in your area..
Nov 09, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Protector glass on a mitsubishi 55in hdtv 1080 #ws-55315
I have the same tv and I took my clear shield off and never put it back on.  The picture is much better without it as it will reflect light and objects in the room making it difficult to see the pic clearly.  I was told by a service tech that the primary purpose of the glass or shield is to prevent damage to the screen from objects, water etc.  If you have no small children in the home you can enjoy a better pic.
Dec 26, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi ws-65907 tv not turning on
Let's just buy new TV's to help stimulate the economy.........
Dec 14, 2008 | Mitsubishi WS-65907 65" Rear Projection...
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi Mod # WS-55315
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Mar 13, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
