Question about Frigidaire PLMV169DC Microwave Oven
The door hinge of our Frigidaire microwave is loose. The door drops down when we open or close it.
  • 6771 Answers
SOURCE: In my Frigidaire microwave, when I close the door, the fan starts automatically with light turned on. Then, I have to open it and have to push hard into down direction. What suppose to be problem...?
One or two of the door switches are defective due to food partical buildup
Posted on Mar 12, 2012
SOURCE: frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Posted on Apr 16, 2012
MicrowaveSvc
  • 9086 Answers
SOURCE: microwave door won't close
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
You can order Panasonic parts here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE: Frigidaire microwave door fallen off
I had the same problem. I removed the door and used a rivet tool. I checked to make sure the door cleared the rivet head, which was nearly flat, so there would not be any microwave leakage.
Posted on Nov 20, 2011
  • 6771 Answers
SOURCE: Frigidaire microwave FMV156DBC turns on with door
One or two of the door switches has failed, replacement only option, consider price.
Posted on Apr 07, 2012
Fix sagging frigidaire microwave door
Hello Rick, thank you for your inquiry!
From my understanding you need to fix a door that is sagging on your Frigidaire microwave. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Apr 01, 2015 | Frigidaire Microwave Ovens
How to repair a broken lower door hinge?
You may need to remove the microwave off the wall but lets try this first. Unplug the micro and then remove the screws around the bottom cover plate. The cover should drop down--watch the wiring to the light system mounted to the cover. Now look at the bottom hinge area. Can yo see and access the screws to the hinge??? Should be 2 or 3 screws. If you can get to them then you can change the hinge there. Tape the door in place so it doesn't drop while doing the repair. If you can't see the screws, you may need to pull the micro off the wall and remove the outer case to do the repair. In some rare cases the hinges are welded to the case and not replaceable.
Mar 30, 2015 | Frigidaire PLMV169DC Microwave Oven
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My hindge on my microwave seems loose and the door is not shuting.
This being a mechanical fault you need to see if there is any play on the hinge. The door must be opened in full and checked if there is any dirt or object on the hinges that prevent the door to come closer. if so clean and use a good degreaser on the hinges.
please check the link for the spares diagram
http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Jul 20, 2011 | Frigidaire Microwave Ovens
Door drops down 1/8' when open. To close need to
If the model number you have this listed under is correct, there is no adjustment. More than likely the door pivot and/or hinges are worn. They can easily be replaced, however. The part numbers are as follows:
Door Pivot - 8184922
Upper Door Hinge - W10114255
Lower Door Hinge - W10114254
You can find these parts at appliancepartspros.com. Just type in the model number and locate items 6, 8, and 13 under the "Door Parts" heading.
If you have questions about this repair, or have a different model number, please post back and let me know so that I may be able to provide better assistance. I hope this helps you.
Aug 25, 2009 | Whirlpool GH5184XPQ Microwave Oven
Frigidaire gallery microwave door sags
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Door is loose, microwave won't cook
The door switch mounts and possibly the door hinges need to be adjusted them tightened.
Unplug the oven, remove the cover if it's a counter top type or remove the grille and control panel if it's an over range type.
Then close the door and watch how the door latch heads on the door mesh with the door lathes and door switches.
Also check the hinges.
If the door latch heads are not activating the upper & lower door switches, then adjustment will be needed.
For many brands, you can find helpful exploded view diagrams and order parts by entering your full model number here.
There is often a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please reply back with your brand and model number if you need more help.
Aug 17, 2008 | Frigidaire FMV156DC Microwave Oven
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Frigidaire PLMV169DC Microwave Oven Logo
292 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
