Question about Sharp MX-M350 All-In-One Printer
We have an error code L4-02 on our MX-M350N Coper/printer...and we need to be able to use it today---service place is closed today.
3 Suggested Answers
dwylie76
  • 80 Answers
SOURCE: My printer (Sharp MX-C311) shows
Make sure the to pressure release levers on each side of the fuser are down. Turn the machine off for a minute then back on and should be fine.
Posted on Nov 10, 2011
SecurityGuru
  • 100 Answers
SOURCE: how do you put a ip address in a sharp mx-m350n
Here is a link the administrator manual (http://www.sharp-ro.ro/dyn_pdf/doc-MX-M350N-139.pdf) on page 13 it tells you how to set the IP address.
Posted on Jan 22, 2010
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Why is my sharp mx 3500n copying blank pages. No error code indication
check the transfer roller/transfer assy or replace the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 28, 2015 | Sharp Office Equipment & Supplies
Sharp copier mx-m350n
Custom Settings > Key Operator Settings > (enter access code usually 00000) > Image Send Settings > somewhere under this heading is the Fax setting to control transaction reports
Oct 25, 2013 | Sharp Office Equipment & Supplies
Unable to print double sided on sharp mx-m350n with window 7
I had the same exact problem. Go to control panel>hardware and sound>devices and printers. Right click the printer and select printer properties. Click the configuration tab and make sure the duplex module is checked. This should solve your problem.
Jul 03, 2012 | Sharp Office Equipment & Supplies
MY AR-M350N COPIER DISPLAYS F1-15 ERROR CODE, IT ALSO SAYS THAT THE FINISHER IS OUT OF SERVICE. PLEASE I NEED A SOLUTION TO THIS PROBLEM
The error code F1-15 means that the stapler is not in home postion. It can also, be that the exit tray is not in "HP" aswell. I would turn the copier off and turn it back on and not use the stapler funcation. To repair the problem, there are a bunch of up dates to resolve this problem. I would change the out put tray from the finisher to the left out put tray... Good Luck
Mar 17, 2012 | Sharp AR-M350N Copier
I have System error E007 problem in my Canon 2018N
you have problem in fuser section must be chek the fuser film
Feb 11, 2010 | Sharp AR-M350N Copier
How do you put a ip address in a sharp mx-m350n thank you.
Jan 22, 2010 | Sharp MX-M350 All-In-One Printer
Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Jan 25, 2009 | Sharp AR-M350N Copier
Sharp MX-M350 All-In-One Printer Logo
358 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
polytek
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
