Question about Health & Beauty
Hi there i have an Enigma class B 8 litre autoclave , it is reading a E4 code can you please tell me what that is .. Thank you Miss Rahimi
3 Suggested Answers
SOURCE: need to know what a
E4 error is a pressure and temperature differential. Check the steam generator solenoid,steam generator water pump and water sensor in clean water reservoir. If any of these components are faulty then replace. If all ok refer to E2 error and check inner temperature sensor or check for steam leaks
Posted on Sep 15, 2010
SOURCE: Enigma b autoclave
Oh no, you have bought a "Runyes" Chinese unit. "Run - Yes" is the best option. Sell it & buy something better.
But, E4 is to do with Temp or Pressure not right.
Code E4:constant temperature and constant pressure failed.
(the chamber pressure tolerance is greater than 0.25bar or temperature tolerance greater than 2.5?)
Solution:
A. please check if you can open the solenoid valve which the steam gets into.
B. please refer to E2 process
For E2 try:
Code E2:Chamber overpressure
(The chamber pressure is above 2.4 bar for longer than 2 seconds)
Solution:
A. Please check when the pressure rises, the chamber inner temperature will also rise up. If not or rise up very slowly, then you should check the inner temperature sensor, please refer to E1-C1 process.
B. The chamber keep vacuum pressure, the vacuum pressure will be -0.7 bar within 4 minutes under normally room temperature, and it will above 0.1 bar within 5 minutes if the pressure do not leak out, otherwise, you should check the chamber cover, solenoid valve, safety valve, vacuum pump, connector welded points, till you find the problems where and why the pressure leak out, then solve the problems if you find it.
C. During the machine normally working cycle, please observe if the machine vacuum could be lower than -0.6 bar, even lower than -0.7 bar if the machine is still cold.
D. Adjust the chamber cover and tighten a little if necessary.
E. When you run a cycle for the first time with a packed or non packed instruments and it comes up with E2, please don't worry. It will not come out with the E2 alarm again when you run it the second time.
Posted on Nov 10, 2010
I have an Enigma 12 autoclave and it keep coming up with fault code E9 what does this mean
On some error 9 is "Time Error" .. the real time clock inside has failed. Normally just a small battery needs replacing but it is a technician job as the machine needs to be opened.
Apr 23, 2018 | Computers & Internet
My enigma autoclave isn't starting. There is no error message on the screen. It just beeps 3 times and does nothing?
I know nothing about Enigma but this is typical of PC problems with memory. If there is a Keyboard, try getting into Bios by restarting and pressing F2 and Del keys alternately on turn on. This gets you into most computer Bios. When there, look for Memory/RAM to see if it is seeing any. Try "Reset to defaults" as a last resort.
Try to get the manual and look for "Trouble Shooting" section. If it has info on memory installation (for example, adding or replacing, read carefully.
If you have a techie guy there, think about opening up the Enigma to get to the main board (mother board) and removing the RAM module(s). If you can have them tested, do so. If not, clean them with a dry clean toothbrush, blow out(or vac) the main board socket the RAM came out of (be sure Enigma is plugged in and off and not too much vacuuming as it builds up static). And if there are more than one RAM, plug in only 1 or reverse the slots or use other slots if there are any. Try all combinations. Power off between each removal/insertion. Be careful and gentile but firm. Be careful of static electricity. Any little "Snap" you hear from touching some thing is a hazard to electronics, so keep in touch with the machine to stay grounded. Hold the RAM, use that hand to touch the Enigma 1st without touching the RAM to the Enigma and then proceed. That grounds you and by default, the RAM safely. Peep the Enigma plugged in but turned off except when testing.
Nov 20, 2016 | Computers & Internet
My enigma 8 autoclave is showing an error code of E21 and this does not appear n my user manual...help
This really comes under the category of laboratory equipment, not digital cameras, I'm afraid.
Aug 10, 2016 | Cameras
Contol panel won't turn on enigma 8
More info needed. What happened before it wouldn\'t turn on. Is it plugged in ( stupid question)? Does the outlet you have it plugged into supply the necessary power? What condition are the fuses in?
May 19, 2014 | Science & Laboratory
Need to know what a E4 reading on the runyes autoclave means
Sep 13, 2010 | Health & Beauty
Enigma b autoclave
Solution:
For E2 try:
Solution:
Sep 12, 2010 | Health & Beauty
Base reads e4
Base unit display flashing "8" and "88" repeatedly and then after several minuteseventually displays "E4" steadily. none of the keypad inputs register - unit is basically non funtioning with the exception of the display. no dial tone on base unit or on any of the handhelds. Manuall trouble shooting guide has no suggestions for this conditions nor does it contain any error code definitions. Have unplugger and replugged unit power source (to see if it would possibly reset) with same results. Would appreciate any assistance or suggestions you could offer.
Thank you.
Jan 05, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Health & Beauty Logo
347 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
