Question about Sanyo PLC XF10NZ Multimedia Projector
I have a sanyo PLC-XF10NZ. It will not turn on. It is plugged in, connected to the computer, the lamp & ready lights are on, and it worked last night. When I try to turn it on it makes the 'start' clicking sound but does not activate the bulb. Any ideas?
  • 2 more comments
  • caedemon Nov 06, 2010
    I have tried to reset it using the power button. The bulb was replaced around 3-months ago and has been working fine. The 'replace bulb' light has not come on yet. It is making the very distinct clicking sound every time I try to turn it on.
    Okay would happen to know
    Okay would you happen to know or recommend any specialist that wont charge us as much as the projector cost??
    Last question for you, what is your best guess as to what a general repair visit would cost from an A/V specialist?
    President:
  • 1,139 Answers
Hi there, there are only a couple of things that can go wrong when you fit a re.placement lamp. I would suggest removing the new lamp you have just fitted and reseat it, making sure that everything is how it should be. The fact that you have not mentioned the lamp life warning light being on makes me think that the projector is certainly detecting a new bulb, it all depends what system it uses. After you have reconnected everything, try turning on the main power switch and then hold down the power button to try and reset the projector. If this does not work then it seems likely that you have maybe a faulty bulb, which is not uncommon.
See how you get on with the above
Thank you for using FixYa
Posted on Nov 06, 2010
  • 2 more comments
  • Kevin Penn Nov 06, 2010
    Ok, if it is making that sound then it is trying to energize the bulb. The only other thing it could be is the control board for the lamp. If the lamp control becomes faulty then this would explain why it is clicking but not energizing. I am afraid to say it but it sounds like this is going to need a specialist repair and wont be something you can do yourself. Unless you are quite electronically minded taking it apart and having a look will not really do any good but it might be worth a go just to double check no wires have come loose inside. If you do decide to do this, please use caution and make sure all power is disconnected from the projector!!
    I dont know of any myself, you could always try the manufacturer and see what they say? Sometimes I surprise myself with the prices they quote. Give it a go, cant do any harm
    I would say there would probably be a set fee to look at it, around $50 I would imagine, then of course there would be parts if needed. Unfortunately projectors can be very very expensive to repair. If the bulb is relatively new you might want to have a look on ebay for a projector that has the bulb gone, you could buy that very cheaply and then put your bulb in it. Obviously make sure your bulb is compatible first. That would probably be the way I would go rather than spend a fortune on repairs.
    Hope this helps
My projector won't turn on. I press the power button and the power/standby light turns on then turns off.
More than likely one of the fans is not running. That could be because of a blown in-circuit fuse or a bad fan motor.
Sep 30, 2014 | Sanyo PLC XF10NZ Multimedia Projector
My Sanyo plc su20n comes on but shutts off after a couple of minutes. Does not give a temp warning just ready indicator goes of and picture goes off. IF you wait a couple of minutes the ready light will...
check the physical nature of the lamp in the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause premature shut off.
Sep 14, 2011 | Sanyo PLC SU20N Multimedia Projector
I have a Sanyo plc-xt25 LCD Projector and when I plug my ac cord in, the fans turn on but no lamp comes on. I changed the lamp and still no picture. What do I do?
Every projector lamp is equipped with ballast. The problem area is ballast. Either the ballast is not getting DC supply or the lamp turn ON signal from the projector main board or the ballast is faulty. Remove the lamp. Connect the projector to the mains supply. Check the voltage at the lamp connector inside the projector without turning it ON. It should be around 65 volts A/C. (Warning: Multimeter will get damaged if the projector power is turned ON due to generation of high voltage) If you find this 65 volts then it confirms that it has DC supply & the ballast is functioning. The ballast receives the the turn ON signal from microcontroller through opto-coupler on the ballast. The ballast opto-coupler can be checked by providing external 5V DC supply between pin 3 (+ve) & 4 (-ve) in turn switches ON the lamp. If this works then there is no problem with your lamp & ballast. The problem lies with the main board. If this does not solve your problem then give me the feedback.
Aug 04, 2011 | Sanyo PLC-XT25 LCD Projector
Lamp replace light is still one even though i replaced the bulb
I'm having this same problem. The Ready light is on Green and the LAMP light is on Red. Replace Lamp light is also on. The device turns on, displays the blue SANYO boot screen for a few seconds, then shuts off.
Jul 14, 2010 | Sanyo PLC XP41 Multimedia Projector
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
Hello, I have a PLC XP45L. As soon as I turn on the projector it goes off. The only light on top of the projector is the READY light. We replaced the lamp last year and probably have around 50 hours on...
good day mr david, just clean the air filter of your projector, check all the fans if working... if this problem occur again your lamp ballast is defective.
jahting
Oct 29, 2009 | Sanyo PLC XP45L Multimedia Projector
Sanyo plc-xt10a will not power up. ready light is not on. power to unit is good.
First, check the lamp/lamp door--the door has a safety interlock that prevents power from getting to the projector. Make sure the power *is* getting to the unit by using a known-good power cord. Also, check the 3 air filters. If one or more was clogged with dust, the unit might have had a thermal sensor trip. There is also an internal fuse on the power supply which may have blown.When was the last time the projector worked correctly? Have there ever been any power problems related to that unit before? If the above checks yield no success, the projector will have to be repaired at a service facility. Hope I was of some help---Rick
Sep 09, 2009 | Sanyo (6103055602) Projector Lamp for...
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
Sanyo PLC-XU33 image displayed for 10 seconds then turns off
Owner decided to upgrade to a newer projector. Lamp was too expensive.
May 07, 2009 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC XF10NZ Multimedia Projector Logo
122 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
