Question about SYMA Toys industrial New Syma S107 Mini Indoor Gyro
I have recently bought the s107 model, it takes approx 1 hour 10 minutes to charge by both charging through usb and the handset. this only supplies 5 minutes of flying time. the instruction booklet advertises that it should take 40-50 minutes. quite disappointed to be honest as the desgn of the helicopter is fantastic! please advise if it is faulty and whether a replacement is necessary?
  • 3 Answers
The 5 minutes is disappointing I agree, but it seems to be normal from what I can tell. Here's a good reference: http://ezinearticles.com/?Syma-S107-Helicopter-Flight-Times&id=5130531
Today I did several use/recharge cycles, and I am fairly sure it was better at the end (went up from 5 minutes to 7). Yours may improve with use too.
As for the charging time, I don't have enough data yet to help, because I've only charged via USB and its behaviour has been weird. At first the light did not go out at all, and latterly it has gone out, but nowhere near for long enough, so on every occasion I've left it plugged in for at least 40-50 minutes. I might wonder if your USB isn't supplying enough power - apparently some laptops in particular don't supply as much power as other computers. That's only speculation but it's probably worth trying another USB source if you can. I've seen others talk about charging in 30 minutes, so there's hope yet. I'd recommend googling on "s107 charging time" - it's come up with lots of hits. Good luck.
Posted on Nov 07, 2010
S107 charger light stays red all the time, doesn't change to green.
Check the batteries are new or in good condition. Also charging time is approx. 30 mins check in the manual how long charge time is. We also have replacement USB mini chargers available.
Kind regards, Julian.
rccontrolfreak.co.uk
Dec 05, 2013 | SYMA Toys industrial New Syma S107 Radio...
I bought a Syma S107 and have enjoyed flying it immensely. I would plug it in to keep it fresh, recharged, and ready-to-fly. Recently, I found that it suddenly wouldn't climb more than an inch high...
Li/Po batteries are meant to be stored charged, so that shouldn't be an issue. Were you leaving it plugged into the charger? This is not the best idea. Not only will it likely slowly sap the battery's ability to hold a charge, if, by some freak happenstance, both the PCB (overcharge protection) in the battery and the one in the charger were to both fail...
POW!
More common than anything I've come across regarding battery death is proper care. These small, lightweight, high output Li/Po batteries NEED to be cooled for 10 minutes after flight, and ALSO after charging. And most important, never drain them completely. As soon as your helicopter cannot maintain altitude, land and power it off. Cool 10, charge until fully charged, (light on charger at it's brightest) cool another 10, fly. Rinse and repeat.
Note: the batteries on the s107 are tricky to replace, micro soldering is required. Sadly, unless you have soldering equipment and know-how you'll probably just have to but another one. If you do, look for the s107's with the pink and green motors, not the black and white ones. Amazon sells the pink/green ones, and is the only place I've found them, look for the ones with "Amazon Inc" as the vendor, and check the pictures. The black/white ones are fine, (I have 3) great even. The pink/green and faster, lighter, far more agile, and are good for a minute or two more flight time based on my experience.
Good Luck, and I hope this helps,
PvT
Sep 11, 2011 | SYMA Toys industrial New Syma S107 Mini...
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
The package says to charge your nuvi 1450 gps for 4 hours. My question is can it be charged on my computer with the usb cable supplied? The only other power cable I have is the one that plugs into the...
You can charge it through your computer with the usb lead. It takes 8 hours approx to charge through the computer while it takes approx 4 hours through the car charger.
Jan 06, 2011 | GPS
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
How to charge battery
There are 3 ways to charge the battery in your garmin nuvi satnav.
  1. Connect it to a computer with the mini USB lead that should have come with it or can be bought in any computer shop. This is the slowest method taking approx 8 hours.
  2. Connect it to your car cigarette lighter with the charger lead which should have come with it. This takes approx 4 hours to charge fully.
  3. Charge with a mains charger. This does not usually come with a satnav but can be bought seperately in shops that sell garmin satnavs. This method also takes approx 4 hours to charge fully.
Dec 29, 2010 | Garmin nuvi 255W GPS Receiver
Can I charge a battery first time for new GPS Garmini 1300 by connecting GPS to computer with USB cable?
Yes you can charge the battery through the computer with the usb cable. However it will take twice as long, approx 8 hours, to charge as the car charger or mains charger which take approx 4 hours.
Dec 17, 2010 | GPS
How to charge a nuvi 1300 GPS
There are 3 ways to charge your Garmin nuvi satnav.
  1. You can use the car charger that should have come with it. Plug the mini USB plug into the satnav and the other end into the cigarette lighter socket of your car. This method takes approx 4 hours.
  2. You can charge it with a mains charger. This doesn't normally come with the satnav but has to be bought separately. Some dealers do throw one in though so it's worth mentioning. This method also takes approx 4 hours
  3. You can charge it with your computer. By connecting it to your computer with the mini USB lead it charges. This method is the slowest taking around 8 hours.
Dec 09, 2010 | GPS
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
SYMA Toys industrial New Syma S107 Mini Indoor Gyro Logo
451 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
