Question about Bosch WFMC 3200 Front Load Washer
Installation instructions for the deflector. Replacement part number 644226 and original part number 494122. It goes on the front og the drum at the top just right of 90 degree top center.
How spring goes on deflector shield
Please wear eye protection for your safety before performing this task since there is a spring that is under load! Take a pair of side cutters and cut the one way lock washer located on the font side of the shaft. (Facing Towards Front of Tractor). It should be black in color. Take a pair of pliers or vise-grips and pull and twist the rear part of the shaft that goes through the plastic deflector and work the plastic deflector up and down while you work the shaft out. As you're working the deflector shaft out, take caution as the spring will pop out of place. To install new deflector, place spring between plastic deflector and align it up to the hinge openings on the deck. Make sure the "L" tab is inserted in the open slot of the plastic deflector. Tilt the plastic deflector towards the back side and start to insert the deflector shaft from the back and wedge it in about close to half way in. Take the front part of the spring that has the rubber tab (to protect deck paint) and twist it counter clockwise so the rubber tab is pointing towards the left side of the deck. Push down on the plastic deflector assembly and continue to work the deflector shaft all the way through to the font hinge opening. Once the shaft has passed all the way through the hinge opening, take a 9mm or 10mm deep well quarter inch socket and tap the new one way lock washer that can be purchased at your local hardware or Home Depot location. Use a soft mallet hammer to do this so you won't damage the chrome finish on the socket. Good Luck and Let Me Know How it Turns Out.
Aug 31, 2013 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
Burning smell in in dryer
Take a flashlight and look inside the drum at the holes on the back end of the drum where the hot air comes in. On mine, there is an air deflector on the back side of the drum and the space between this deflector and the drum was packed with lint. The lint blocked about half the holes. I had to take the drum out, remove this deflector by removing four screws inside the drum then cleaning out the lint. The lint was all brown and scorched.
Jun 07, 2009 | Whirlpool LER4634J Electric Dryer
The turn on lights does not flash
Check out this recall below:
Bulletin No.: 04098A
SPECIAL POLICY
Subject:
04098 - Special Policy Adjustment - Turn Signal/Hazard Warning Flashers
Condition
Some customers of 1999-2002 Chevrolet Malibu, Oldsmobile Alero, Pontiac Grand Am, and 1999 Oldsmobile Cutlass may have turn signal/hazard flashers that become inoperative.
This special policy covers the condition described above for a period of 10 years or 150,000 miles (240,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
Good luck and hope this helps:
HAZARD WARNING SWITCH REPLACEMENT - ON VEHICLE
REMOVAL PROCEDURE
Remove the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
Remove the instrument panel cluster.
Remove the hazard warning switch bezel from the instrument panel using a small-flat bladed tool to release the retainers.
Remove the left side bolt from the hazard warning switch through the instrument panel cluster pocket Remove the right side and center lower bolts from the hazard warning switch through the center air louver deflector pocket.
Reposition the hazard warning switch from the instrument panel to access the electrical connector.
Disconnect the electrical connectors from the hazard warning switch.
Remove the hazard warning switch from instrument panel.
INSTALLATION PROCEDURE
Connect the electrical connectors to the hazard warning switch.
Position the hazard warning switch to the mounting points in the instrument panel. NOTE: Refer to Fastener Notice in Service Precautions.
Install the left side bolt to the hazard warning switch through the instrument panel cluster pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the right side and center lower bolts to the hazard warning switch through the center air louver deflector pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the hazard warning switch bezel to the instrument panel pressing into place until fully seated. Install the instrument panel cluster.
Install the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
May 24, 2009 | 2000 Oldsmobile Alero
1st time install of OEM fog lights into a 1999 Mercury Cougar?
Look under the dash near where the headlamp switch mounts and if yours is equipped you should see I think it is a blue 4 pin connector with the following wire colors OG,OG/WH,OG/GN,BK.
This is for the fog lamp relay.If yours has this connector then you will need to purchase a relay ford part number F6RZ-14N089-AA should list for about $10.
Feb 25, 2009 | 2000 Mercury Cougar
Bosch WFMC 3200 Front Load Washer Logo
74 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
