Question about Gateway 10C2300-G - 10GB NOTEBOOK HARD DRIVE KIT FOR COLORBOOK 2300 SERIES (10C2300G)
When i boot my computer it says no bootable partition in table and after a while i keep trying it will boot up but i go through this every morning
  • Gateway Master
  • 19,396 Answers
Hi.
That means that either the master boot record is damaged, or that the computer is attempting to boot from a non bootable disk (more likely).
First ensure that the system is not trying to boot from a different device. If it happens with USB disks or other mass storage devices connected, then that is the problem. Ensure that there is no device connected. Eventually go to BIOS settings and check boot settings. Ensure that BIOS is set to boot from HDD first.
If that is not the problem, then you have a corrupted master boot record, or a corrupted boot.ini file with multi boot(less common). In the last case one of the boot entries in boot.ini is pointing to a non bootable record. This is not common, and you need to select the non bootable or corrupted partition manually on startup, forget about this case for now.
If there is no USB or external device connected, and if BIOS boot settings are OK, then you have a problem with the hard disk where the system is installed.
As first thing do a backup of all the files, then try using a partition recovery software to fix the problem. If that does not work, then better reinstalling Windows.
Here an utility: http://www.ptdd.com/partitionerror.htm
Regards.
Ginko.
Posted on Nov 06, 2010
I own an ACER 4315 Laptop computer MS2220 Atheros AR5BXB63 with Windows Vista Home Basic. I'd like to partition the hard drive to run Ubuntu Linux. However the Ubuntu 7.04 Liveboot CD not recognized as a...
Hello there.
Nice to see more people trying out Linux :-)
From your description it sounds like the CD image you downloaded is not bootable. What i would do is scrap that CD and try the following, this is a guide that explains step by step how to take the downloaded .ISO file and burn it to CD, so that the computer can boot from it (known as a bootable CD).
Please click here for the information.
As Ubuntu has a partition program as part of the installer, you can use this to resize your Windows partition and install Ubuntu in the free partition left over.
This should get you setup in no time :)
Hope this helps.
Jul 04, 2008 | Acer Computers & Internet
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Master Boot Record
MBR Short for <i><b>M</b>aster <b>B</b>oot <b>R</b>ecord,</i> a small <a href="http://www.webopedia.com/TERM/P/program.html">program</a> that is executed when a computer <a href="http://www.webopedia.com/TERM/B/boot.html">boots up</a>. Typically, the MBR resides on the first <a href="http://www.webopedia.com/TERM/S/sector.html">sector</a> of the <a href="http://www.webopedia.com/TERM/H/hard_disk.html">hard disk</a>. The program begins the boot process by looking up the partition table to determine which <a href="http://www.webopedia.com/TERM/P/partition.html">partition</a> to use for booting. It then transfers program control to the <i>boot sector</i> of that partition, which continues the boot process. In <a href="http://www.webopedia.com/TERM/D/DOS.html">DOS</a> and <a href="http://www.webopedia.com/TERM/W/Windows.html">Windows</a> systems, you can create the MBR with the FDISK /MBR command. <br /> An <i>MBR virus</i> is a common type of <a href="http://www.webopedia.com/TERM/V/virus.html">virus</a> that replaces the MBR with its own code. Since the MBR executes every time a computer is started, this type of virus is extremely dangerous. MBR viruses normally enter a system through a <a href="http://www.webopedia.com/TERM/F/floppy_disk.html">floppy disk</a> that is installed in the <a href="http://www.webopedia.com/TERM/F/floppy_drive.html">floppy drive</a> when the computer is started up. Even if the floppy disk is not <a href="http://www.webopedia.com/TERM/B/bootable_diskette.html">bootable</a>, it can infect the MBR. <br />
on Dec 22, 2010 | Computers & Internet
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
Trying to reformat mini dell with no cd rom drive tried to boot from usb but comes up with No bootable partition in table what does this mean
Recovery discs have certain run procedures, flash drives dont. I would suggest you obtail or lend and external USB writer
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
Tip
"Unable to find a free MBR slot in virtual partition.dll usually due to no free...
Situation:
When attempting to run an operation in Ghost that requires a reboot into the virtual partition, you receive the error "Unable to find a free MBR slot in virtual partition.dll--usually due to no free slots on disk."
Solution:
This problem occurs when the client computer has used up all four primary partitions in the partition table of the boot drive. An Extended partition takes up one Primary Slot, so having three Primary partitions and one Extended partition would also cause this issue.
Computer architecture allows each hard drive to have no more than four primary partitions (the other partitions are extended partitions). Because the Ghost Virtual Partition is implemented as a primary partition, you see this message when the disk is using all four primary partitions and does not have an available slot for the virtual partition.
Use one of the following methods to resolve the problem
  • Start the computer from a Ghost bootable floppy disk rather than a Ghost Virtual Partition. You can use Ghost Boot Wizard to create a Ghost Standard Book Disk for this purpose.
  • Repartition the disk. If you repartition the disk, ensure that you create backups of your data before doing so.
on Feb 01, 2010 | Computers & Internet
Drives - size
Resizing partitions is easy with the right tools, and near impossible without them. You will want to first
get a good hard disk imaging program along with an external hard drive (some drives come with imaging software bundled with the drive) a few examples would be Norton Ghost, Acronis True Image, Dantz Retrospect, Powerquest Drive Image and so on. There are even some good freeware and Open Source alternatives. By imaging your c: drive to a USB external drive you can safely edit your hard drive partition tables and then put everything back with no reinstalling Windows or losing any data. You will need to have a bootable recovery CD on hand when it comes time to restore the image from the USB drive to your system drive. I would suggest that you first copy all files you want to keep from the d: e: and f: partitions to the c: partition, then image the c: partition by itself to external drive. Take note of the c: partition type I.E. FAT32 or NTFS. Make a bootable utility disk (Ultimate boot CD available from Filehippo.com for free) is one, an emergency boot floppy from Windows 98, ME, NT will work also. Boot with it and run FDISK to delete extended drive letters D E F and then their partitions and then delete the C: partition and finally create the C: partition with all available space and make it active. Replace the utility boot disk with the recovery boot cd, restart the computer and run the image recovery to restore everything back to your now 80gig system drive.
Jan 07, 2009 | Biostar NF325-A7 Motherboard
Reinstalling Problem
Once you disrupt the partition table by introducing a new linux partition the recovery program is unable to identify the recovery partition. The only success I have had is to boot from a program called partition table doctor and using it to rebuild the master boot record and partition table structure, you can download it here: partition table doctor
of course there is no guarantee it will cure your problem but it is a very powerful tool I have used with some success. Please rate my assistance as we depend on your rating to carry on giving FREE advice.
Mar 29, 2008 | Compaq Presario Notebook
Open Questions:
Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 19, 2018 | Toshiba Computers & Internet
See all Gateway 10C2300-G - 10GB NOTEBOOK HARD DRIVE KIT Questions
Computers & Internet Logo
228 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
