Question about Maytag Washing Machines
We have a magic chef washer that is letting the cold water run in constantly, even with the power off. also, it will not spin out now. model# cav2000aww. serial# 14430432ae.
  • 487 Answers
Your valve( inlet valve ) is broken or stuck due to residu
You have 2 water valves. Most likely it is the one directly where the hose connects.
Follow LINK for drawing and Parts
Posted on Jun 15, 2008
What the cause when machine loads water but won't wash,
if the motor runs but dont adjitate its poss.the coupler if it dont run may be in the lid swich or timer
May 06, 2014 | Magic Chef CAV2000 Top Load Washer
I have a magic chef 10.1 kg super capacity heavy duty washer model W224lgv serial 10569997sf with hot water problem. only cold water goes in , pump allows to cold water to go in
(pre-typed for hot AND cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 08, 2011 | Magic Chef Washing Machines
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
MAGIC CHEF WASHER SPINS WATER OUT MAKING CRAZY NOISE & THE WATER GOES OUT ON THE FLOOR. WHAT'S WRONG? DOES THE PUMP HAVE TO BE REPLACED?
could be.pop the top and take off frount cover.run unit and look where water coming from.could alos inspect pump the pully dose come off on those an then drag metal to metal but normaly no water leak.also could be a bad tub seal you would see leaking from under neath
Dec 31, 2008 | Magic Chef CAV2000AWW Top Load Washer
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer wont spin
if the belt under the washer is intact then the transmission is bad. generally its time for a new washer unless its still under warranty
Nov 22, 2007 | Magic Chef CAV2000 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
