GE top load washer won't drain or spin
My washer went through the regular wash cycle. it filled with water for rinse, but when it switches to drain and spin, it just hums. Model # WWSR3090T8WW
  • hhart Sep 01, 2008
    I had the same problem...just change bearing under the transmission
There was something stuck in the water pump. we pulled it out and good to go.
Posted on Jun 15, 2008
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
