Question about Reddy Heater-30-55,000 BTU Variable
Getting to much kerosene floods sparkplug and wont light
  • 1 more comment
  • paulthwall Nov 06, 2010
    thats not the problem,it is spraying to much kerosene. it just floods the spark plug, I put in new spark plug it started and when I shut it off It wont start again because its 2 wet.
  • paulthwall Nov 07, 2010
    Im still getting to much fuel,thus drowning the spark plug, which wont let it fire.
    my heater fired after adjustment but when you turn it off and later turn it on, it wont fire.
  • 2,973 Answers
The carb is flooding. Please clean the card properly as its float does not seem to be working. It is not moving up with the liquid to stop the flow of Kero. It needs to be cleaned and adjusted.
Posted on Nov 07, 2010
  • Reddy Master
  • 43,501 Answers
There are a number of issues that keep these kerosene heaters from working properly.
One of the most important is the fuel pressure. The procedure to adjust this requires that you have the right tools and the time to set it up. It sounds like your air/fuel mixture is not right and that is why your heater is not lighting...
Here are a couple of tips that I wrote that tell you how totroubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
  • D. Floyd Kolb
    D. Floyd Kolb Nov 07, 2010
    Okay...then you have a bad nozzle....it is not holding a constant flow....not uncommon...
    President:
  • 1,383 Answers
Fuel adjustment screw is found by following the airline tube from nozzle to pump. The air line is attached to vane pump that forces air into the nozzle. The velocity of the air is what draws fuel from tank. Small plastic screw next to air filter screen may be turned in for more air and out for less air thus more or less fuel. I have found that the quality (new/old production) of the kerosine has much to do with wet plug (seemingly too much fuel). Old fuel or diesel fuel will not readily light. Start with fresh kerosine and gradually add/mix old fuel.
Posted on Nov 06, 2010
  • John Trevino Nov 10, 2010
    These heaters are rather crude and are not exact in fuel air ratio; then add to that the question of the fuel (old /new, kersonine , diesel , coleman fuel? ) Making these heaters run is like starting an old car with manual choke. The heater works best (efficient with fuel ) when flame is burning lean but gets hottest when fuel is spraying rather rich. I would adjust lean / rich screw to work best when burner is hot and running well. This condition /setting may not be best when starting cold. You can play with the amount of air being pumped into jet by restricting air filter with your hand. If you cover the filter less air can be pumped to nozzle thus less fuel is punped in at start. Also you can restrict the amount of air that is blowing thru heater (large volume of air blowing thru heater tends to blow out flame) by restricting opening at rear with piece of cardboard. Good luck
  • 6,993 Answers
This is called over floating. Leave the machine for a while (maybe couple of hours) and try again. By then the over floating would have stopped.
Or, remove the spark plug, scratch it against the ground, fix it back in and try again.
Any of the above should fix this problem.
Good luck.
1992 jeep cherokee 4.0 liter inline 6. Why would it flood out when you turn off the key? Have changed the tps, map, sparkplugs & starter.
flooding out is a furl /injector problem could be excessive pressure or leaking injector seal or bad injectors
Jul 08, 2017 | Cars & Trucks
Our basement flooded out and we are now drying it with a kerosene fueled heater that blows heat. We have no ventilation. are there any effects from breathing in the fumes?
ABSOLUTELY NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!This will put out carbon monoxide, which is very deadly.get a dehumidifier.
Feb 17, 2010 | All-Pro Forced Air Kerosene Space Heater...
My 95 sunfire wont turn over all the way . the lights still turn on and its so close to starting but it wont. do u think its the sparkplugs
Be aware that the lights only take a few amps to work; however, the starter takes 250-300 amps. So make sure the battery is fully charged 1st to get a 100% crank. If you're still having trouble you could have flooded so mat the accelerator & try that. Beyond the simple a full fledged tech will help you
Oct 17, 2009 | 1995 Pontiac Sunfire
Wont start 1996 jeep grand cherokee laredo inline six4.0 fuel inj
The first thing I would do since you think it was flooded is to replace the sparkplugs, sometimes if a spark plug has been washed out with gas you cannot get it completely dried out. After you replace sparkplugs try to start the engine. If the engine starts I would still recommend that you change your oil because of fuel saturation. If your engine fails to start I would suspect that you have a bad crankshaft position sensor as it is known to give problems. The crankshaft position sensor is located on the top of the transmission bell housing on the drivers side.
Oct 02, 2009 | 1996 Jeep Grand Cherokee
Flooding ,to much fuel .to engine ,it is not the fuel regulator
your sparkplugs might not burning all the fuel thats why its flooding. try changing your sparkplugs for better burning
Jul 02, 2009 | 1988 Nissan 300ZX
Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Jun 27, 2009 | Garden
WONT FIRE
have you cleaned the air inlets? I have a older (1970's) reddy heater, occasionally it starts getting smokey or not firing at all. I open up where the air filter is and clean out the chamber with carb cleaner; gets the old girl firing up nice again.
Jan 07, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
200T would burn
During start up, a hot surface ignitor glows brightley to ignite kerosene, check to see if it is broken
Nov 08, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater-30-55,000 BTU Variable Logo
32 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
