Question about KitchenAid KESS908SPS Electric Kitchen Range
Glass top stove hard to work
We have a problem getting the stove top elements to work. some work better than others.
the oven controls work perfectly every time.
do these buttons detect heat or capacitance
perhaps thr detectors are spaced too far frm the glasstop
  • Leonard Wolff Jun 15, 2008
    I am not talking about operations as it is cooking.
    I cannot get the tap touch to work. It worked for the repairman, but not for me. He even thought I was not holding my finger down hard enough and pushed on the top of my finger to no avail.
    Once I get it to turn on it seems to work better.
    The tap touch works on some of the burners work better than others. My question is: does the tap touch on the top burners work by sensing your finger heat or does it work on capacitance?
    The oven controls work perfectly, its only the top burners tap touch that is the problem. Is it possible that the sensors are a little too far from the ceramic top?
  • 77 Answers
Glas tops usually detect both heat and time of unit on cycle. notice how burner turns on and off when on lower settings. the biggest issue i get on glass tops is cookware. the cookware should "FLAT!!" bottoms, owners manual suggests using a straight edge to determine. I have tested very expensive cookware ($200 a pot) and it seems to not be flat enough. much expensive cookware is designed to be used on gas tops. pans should also be of a medium weight. I tell people before they buy a glass top, plan on spending nearly as much on your cookware as on the range. A good set of Calphalon (not an advertisement) non-stick is about $500 -$600.
The top has built in sensors that shut the burner down when heat is trapped in an air pocket under the pan. this causes the burner to shut down prematurely and take much longer to cook.
Posted on Jun 14, 2008
  • Jim Gillon Jun 15, 2008
    It is a capacitive touch system. ground at wall plug must be tight and clean. I would recommend a 4 wire system as required in new regs.
    New Friend:
  • 81 Answers
Yeah!!!! I can understand your problem and for this I have a simple suggestion for you and that's always see and refer some authentic reviews so that you won't face this kind of problem in future. For more details, please visit here:
GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Posted on Jul 23, 2015
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
My Maytag Performa glass top stove does not work. The oven doesn't heat up but the stove top works fine. I checked my fuse box downstairs and it is fine. I checked the stove to see if there were any...
Dear Gina,
It should be one of 3 things.
1) The element has burned out, or
2) The socket the element plugs into has failed, or
3) the wires hooked to the socket have toasted.
Someone must take the stove apart to see.
God bless your efforts.
Oct 26, 2017 | Maytag PER5710 Performa Electric Kitchen...
How to change cooking element on top of stove. is there a detail drawing and manual stove is 4 year old
Electric stove top? Is the element a coil or soild element? Or is it a glass top?
Feb 07, 2011 | Ovens
My 790.94322302 Kenmore Oven & Broiler stopped working
The odds of both elements going out would be unusual.Tried to look up any other parts but the only other thing is the control module without having a wireing diagram.There should be one on the back of the stove if you can trace wires back from elements.I know that if the oven is in clean mode it over rides the oven controls.But with the electronic controlls don't think that it is possible.
Feb 01, 2010 | Kenmore Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Jan 03, 2009 | GE JKP15 Electric Single Oven
Glass top is scratched no matter what I do. oven doesn't work ri
glass top stoves are not designed to do canning on, sorry. the only thing you can do for the top is that special cleaner as it has a "wax" in it and will help to prevent stains, but not scratches.
remember your top is glass and it will scratch.
your oven can be calibrated to help it to bake better. what you need to do is make sure you have a temperature problem that can be corrected by calibration. try to just set the oven temps up or down 10 or 20 degrees and try to bake the same items. if this helps then you can reset the calibration of the control as per your owners manual, if you dont have one then i can tell you how if you can tell me the brand and model.
Dec 11, 2008 | Tappan TGF320 Gas Kitchen Range
New installation, does not heat
I think your ignition does not work.
Is this a brand new oven ?
Does it have a stove on top ?
does the stove work ?
Dec 28, 2007 | GE Profile JT915 Electric Single Oven
Open Questions:
KitchenAid KESS908SPS Electric Kitchen Range Logo
505 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
