Question about E-Machines eMachines Desktop PC
Sidebar in Vista quit working
I have an eMachine T5082 running Vista Home Basic. The sidebar quit working. The icons are there but don't do anything and cannot be changed.
  • 106 Answers
Try one of the following:
http://www.winhelponline.com/articles/208/
I ran into this problem at some point, I'd try and re-registers some dll's..
Do the following:
Start/Run -- type "CMD" black DOS screen opens up, then type the following:
regsvr32 scrrun.dll
regsvr32 jscript.dll
regsvr32 msxml3.dll
Uninstall the gadgets and re-install them. Let's hope this works.
Posted on Jun 15, 2008
Hi i want to remove the sidebar with the web cam application hen i am on internet i cant see my pages because it shows the sidebar
To turn Windows Sidebar off:
vista_sidebar_icon.jpg 1. Right-click the Windows Sidebar icon on the taskbar (it looks like the image to the left). If you do not see this icon, click the "Show Hidden Icons" arrow (it looks like the image to the right), then right-click the Windows Sidebar icon.
2. To temporarily disable the Windows Sidebar, click "Exit". Or, to permanently disable it:
* Click "Properties"
* The "Windows Sidebar Properties" dialog box will appear. Uncheck "Start Sidebar when Windows Starts".
* Click "OK".
* Finally, right-click the icon again and click "Exit".
To turn Windows Sidebar on:
1. Click the Windows button on the taskbar, enter "sidebar" (without quotes) and press the Enter key.
2. Now, if you want to permanently enable the sidebar when Windows starts:
* Right-click the Windows Sidebar icon, choosing "Properties".
* The "Windows Sidebar Properties" dialog box will appear. Check "Start Sidebar when Windows Starts".
* Click "OK".
Aug 14, 2011 | Toshiba Satellite C655D-S5120 Notebook
Tip
Windows Vista: How to enable or disable the Sidebar
The Windows Sidebar, introduced with Windows Vista, is a way to have one-click access to websites and widgets right from your desktop. Some people love the Sidebar and some people hate it. Whichever camp you happen to fall in, enabling or disabling the Sidebar is a painless process.
To disable the Sidebar:
1. Right click on the Sidebar icon in the notification area (a computer screen with different colored blocks on its right side).
2. Select Exit from the menu.
3. If a confirmation window appears, click Exit Sidebar.
To enable the Sidebar:
1. Click the Vista orb and type "sidebar" into the Search bar.
2. From the search results, select Windows Sidebar. (If Windows Sidebar is the highlighted item, you can just hit Enter.)
3. The Sidebar will appear, in the same place and with the same widgets as the last time you used it.
An alternate way to enable the Sidebar:
1.Click the Vista orb.
2. Select All Programs.
3. Select Accessories.
4. Select Windows Sidebar.
To configure the Sidebar to load automatically every time you start your computer:
1. If it's not already enabled, enable the Sidebar (using either of the methods described above).
2. Right click on the Sidebar icon in the notification area.
3. Select Properties.
4. Put a check mark in the box next to "Start Sidebar when Windows starts."
5. Click either OK or Apply.
If you have the Sidebar set to load automatically and then you disable it, it will still run every time you start your computer, unless you remove the check mark next to that option in the Sidebar properties.
on Jan 09, 2011 | Microsoft Windows Vista Home Premium with...
Windows 7 gadgets working wrong
You dont need side bar anymore, rightclick anywhere on desktop and goto gadgets, Add the ones you want, put them where you want (side, top, anywhere) and thats your gadgets as they were in vista.
If you have installed Windows 7 beta then you must be aware of the bug that whenever UAC is switched off, Sidebar and Gadgets in Vista fails to display properly on Windows 7 Desktop. Though this is not for every machine but many users have reported this problem that their Sidebar and Gadgets are not working properly.
For older beta versions of Windows 7 there had been some temporary workarounds for the same problem. But if you are using Win7 Build 7000.0.081212 then this can be fixed using a simple registry hack which like in Vista will Elevate your Sidebar and Gadgets Process.
If you know how to play with you registry Editor then just open regedit.exe from Run command in Windows 7 and go to KEY
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
\CurrentVersion\Sidebar\Settings From there edit the DWORD value of AllowElevatedProcess and set it to 1. You don’t need to restart your Windows 7 computer after this. If your sidebar and Gadgets were not working properly earlier then they will be fixed instantly.
Jun 19, 2010 | Microsoft Windows Vista Home Premium with...
Window vista crash how do i fix it??
1.First be sure that ur side bar is closed,ie nothing is running in background.RIGHT click on side bar icon in system tray,chose EXIT button.U will get a message,asking if u really wants to close,click OK.
2.Check task manager to be sure that no Sidebar.exe process is running.if any one running,close it.
3.Open window explorer &paste following into location bar:%localappdata%\microsoft\Windows Sidebar
Sidebar gadgets folder will open with a file named Settings.ini.Once u re-lounch sidebar from Start menu, new settings.ini is created immediately.
With any luck, u should now have a new workink sidebar.
Apr 10, 2010 | Microsoft Windows Vista Home Premium with...
I HAVE A T5082 WITH VISTA HOME BASIC I PURCHASED
problem will be with low watt supply, check the manula of graphic card, and use the power supply of the recomanded Watts
Feb 10, 2010 | E-Machines eMachines Desktop PC
I turned on my PC one day, and sidebar just decided not to go. I dont know why or how to fix the problem. I went to do a system restore, but noticed i had no system restore points set.....can anybody help...
Having a sidebar problem would indicate you're using Windows Vista, so I'm going to go from there. Microsoft has had a lot of problems with the sidebar feature, and has dropped it in Windows 7. I strongly recommend that you turn it off and leave it off. You can get things you need for your desktop without using the sidebar.
As far as the restore points go, you should have several set up automatically, but since you don't do the following:
Click on the start button, then find "Computer" (or My Computer) in the right column. RIGHT click on Computer, then left click on Properties. This brings up the System window. Select System Protection from the column on the left side of the window (Task List). Click the CREATE button near the bottom of this window to create a restore point.
Give the Restore Point a unique name of your choosing.
Of course this won't help you now, so I would shut off the Sidebar and try to live without it. Otherwise, go to the Control Panel, find the sidebar icon and click it. Set it to open the sidebar when you start Windows. You may need to reset your preferences to get it back to what you wanted.
If this doesn't work, you probably have some type of Malware or virus on your system. The best way to check for this is to go to the following web page: www.malwarebytes.org - and download the program using the blue button. Install it (click RUN) and update it, then let it run a scan (follow the instructions). Once it's done, restart your system and see if it's fixed.
Usually, restoring your system for a sidebar problem really isn't a useful or good way to resolve the issue. For one thing, on some systems, the sidebar seems to randomly decide not to work, and on others it seems to cause other system problems. I've seen very few Vista systems that did not improve with the sidebar feature shut off.
It's important with Vista to be very particular about keeping the Malware off the system, and keeping the registry clean. Using CCleaner.exe is a good way to do this. Clean the registry at least once a week, and do NOT defrag more than two times a year. Vista seems to not appreciate too much defragging. Keeping your system healthy and shutting off the sidebar are two of the best solutions for most Vista problems. Finally, I recommend you upgrade to Windows 7 as soon as possible. Even the RC-1 is better than Vista.
Oct 09, 2009 | Computers & Internet
My gadets slide bar has gone how do i get it back
To open Sidebar
Open Windows Sidebar by clicking the Start button , clicking All Programs, clicking Accessories, and then clicking Windows Sidebar.
To keep Sidebar visible at all times, you must set it so that other windows won't cover it. The Sidebar width is a fixed size.
To keep windows from covering Sidebar
Because of the space Sidebar requires, this option works best if you're using a large or wide-screen monitor or multiple monitors.
1.
Open Windows Sidebar properties by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Windows Sidebar Properties.
2.
Select the Sidebar is always on top of other windows check box.
3.
Click OK.
Sep 18, 2009 | HP G70-250us Notebook
Windows sidebar stopped working
Here is a solution I found when I was having problems and it worked like a gem..its a problem with two programs running a .dll file:
1. Open a command prompt by being Administrator (Right click on Command Prompt and click Run as Administrator)
2. CD to C:\Program Files\Windows Sidebar ( cd drive letter:\Program Files\Windows Sidebar )
3. Run these commands in this order:
1. regsvr32 -u sbdrop.dll
2. regsvr32 -u wlsrvc.dll
3. regsvr32 atl.dll
4. regsvr32 sbdrop.dll
5. regsvr32 wlsrvc.dll
Then start up the sidebar.
Good luck. If you have any questions let me know.
Apr 02, 2009 | Microsoft Windows Vista Ultimate Edition
Slow performance - Frequent Hanging of system
Do you run the Aero them with the glass windows effects etc. and have the windows sidebar running? I have found that this tends to slow down my computer a lot.
To turn off Aero:
  1. Right click on an empty area of the desktop
  2. click personalize
  3. click window colour and appearance
  4. select colour scheme:"windows vista basic"
  5. click ok
To turn off sidebar:
  1. go to start-> control panel
  2. Click windows sidebar
  3. deselect "start sidebar when windows starts"
  4. click ok
  5. on the task bar right click the windows sidebar icon
  6. click close
Mar 08, 2008 | Microsoft Windows Vista Ultimate Edition
E-Machines eMachines Desktop PC Logo
56 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
