Connecting my TH37PX8BA Panasonic widescreen to my Toshiba U500-1EO laptop
  • 13,433 Answers
So you must connect your laptop to the TV with a HDMI cable. After which you must turn the TV into the proper source for the hdmi. If you need help in doing that let me know, it does read in the user manual how to change source or input.
Next step you need to turn on the display output from the laptop.
Please follow the instructions exactly.
So on your desktop you right click on the background and from the drop down menu select Screen resolution.
On the display set up page if you will see one screen with number 1 on the middle of it, thats your laptops display. Now, click on the detect button.
This will detect all the displays connected to the computer, and you might see your background on the tv now.
Okay - if you do see your background picture or color on the tv screen, notice which side the display numbered 2. is from the display 1.
Lets say the display 2 is right from display 1. So now you move your mouse out from the right side of your display and it appears on the tv's screen.
if you don't have picture, do you see a disconnected display option on the screen? if you do, click on that and then change the multiple displays to either duplicate or Extend.
duplicate option shows the same picture on both screens.
extend option extends the desktop space to that monitor.
Then apply and picture should show up on the tv.
If this didn't work, look at the F1 F2 F3 ---- F12 keys on the keyboard one of the F keys will have a special function and a icon that represents switching display signal output. If you press FN down and then tap on that key once it will change the setting and you should get picture.
Now if any of this didn't work, and it does work, then you have done something wrong, the tv is probably set to the wrong source or input, go over all the source options to find the one where the pc image is coming from.
That is it, you will get your computer connected to your tv by following the above advice, I assure you that this advice is correct and it will work. I have 4 displays on my own machine including a 30" lcd and know for sure that this does work.
Posted on Nov 06, 2010
The TV inputs screen will not recognize a Toshiba VCR I've connected to it with red,white & yellow cables.
Because many VCR were not designed to work with these types of TV and the TV has no SCART socket you might have to convert it to fit.
You can do this using a box on sale at Amazon.
http://www.amazon.co.uk/SCART-HDMI-converter-convert-connect/dp/B0092IAA3I
Mar 16, 2016 | Panasonic TC-P42C2 Plasma TV, 41.6 -...
I would like to connect my Toshiba satellite C650D 026 laptop to a Panasonic LCD TV what do I need?
if you have HDMI port on your laptop connect it through that or connect it through the vga port of the laptop to the lcd
Feb 02, 2013 | Computers & Internet
Toshiba Satellite C655D-S5130 will not come on. Light flashes on front of laptop for a few seconds then stops
The problem is most likely in the DC jack in the laptop, shows a variety of symptoms because of bad solder joints. The computer will need to be dismantled down to the motherboard level to address this.
May 04, 2012 | Toshiba Satellite C655D-S5048 Widescreen...
How do I replace screen on satellite c655-s5132 with screen from satellite L305-s5919?
I'm sorry, but this isn't possible. The screens are two different sizes. The Satellite C655-S5132 has a 15.6" Widescreen display while the Satellite L305-S5919 has a 15.4" Widescreen display. The two aren't interchangeable. Sorry!
Thanks, and have a great day!
Sep 28, 2011 | Toshiba Satellite Laptop / Intel Celeron...
My Toshiba Satellite refuses to Shutdown or Restart even if I press the power button long.
Hello.
Disconnect the power cord/adapter, flip the laptop and unlock and remove the battery, Reinsert the battery, lock the battery, reconnect the power cord/adapter and power up.
Hope this helps.
Sep 14, 2011 | Toshiba Satellite L645-S4059 14.0"...
Toshiba Satellite L305-S5907 15.4" Widescreen Can
With the Toshiba Satellite L305-S5907 Laptop, you can put a 500GB hard drive and up to 2 TB hard drive. The only requirements are to make sure it has a SATA connector and is 2.5" Size. These are very common and easily found online. For example, here a 500GB one that is compatible that I found: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | Toshiba Satellite L305-S5907 Laptop
Transfer from Widescreen camcorder through S video results in Full Screen instead of Widescreen
have you set the dvd to widescreen? i know some change automatically when there is widescreen input but some need to be changed manually. This should be in system settings. hope this helps
May 19, 2009 | Panasonic DMR-ES10 DVD Recorder
Windows media cant play my video
Generally that means there is a short circuit inside the cable. Try changing the USB cable, and if that doesn't work, you might have a problem in the camcorder.
Feb 14, 2008 | Toshiba Satellite A135-S4527 Notebook
VGA input
is your laptop capable of sending widescreen video to your TV or can it only send 4:3 video?
May 25, 2007 | Polaroid FLM-2632 Television
Computers & Internet Logo
David Payne
David Payne
