Question about Kenmore 73952 Gas Dryer
Kenmore Dryer Model 110.73952102
Exactly where can I find the thermal fuse on the dryer? Can I replace it myself?
    Novelist:
  • 161 Answers
Yes, It is usually on the heating element tube. Don't just replace the fuse. You must find out what caused it to blow. You probablly have restricted air flow . Usually this is a clogged duct pipe or outside vent. This can also be caused by trying to operate the dryer with the door open. Before replacing the fuse, take the duct off the back of the dryer. Clean out what lint you can , turn on the dryer and see if you get good air flow. Next check the vent pipe for clogging and check the outside damper. DO NOT USE FLEXIBLE PLACTIC DUCT PIPE. It is a fire hazard and almost always clogs up fast. Another possible solution is that if it's an electric dryer, If the element burns out it can short out against the frame and cause it to overheat.
Posted on Jun 29, 2008
My Kenmore dryer just died on me! Nothing showing won't start. Model #796.40272900, serial #104KWVQCG983 purchased 6/30/11. Help!
There is a fuse device called a thermal limiter, it is most likely open due to dust and dirt inside the cabinet of the dryer causing an overheat, remove the front of the dryer and locate the thermal limiter and replace it. You can get exact help and the part from this website, I use them myself. Appliance Parts Accessories Repair Help
Apr 20, 2017 | Kenmore Dryers
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
My name is Peter. I am a retired field service appliance technician.
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
I have an old kenmore model 002586 dryer that just stopped and won't start. I think it may be a thermal fuse, but am not sure exactly where it is located. Would you know?
Unplug the dryer.
Remove the rear panel of the dryer.
Look on the left side of the main exhaust vent. The fuse is about 1 and 1/2 inches long by 1/2 inch wide and white in color.
2 wires attached.
Sep 09, 2010 | Kenmore 67632 Electric Dryer
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer
http://www.partselect.com/dryer+replace-thermal-fuse+repair.htm
Jun 14, 2008 | Kenmore 73952 Gas Dryer
Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
May 05, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
236 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
