Question about Sanyo Microwave Ovens
Please help Microwave starts when door is closed but display is still saying to close door and not counting down time
  • Sanyo Master
  • 9,047 Answers
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
If you still need help, please reply back with your brand and full model number from the tag on / in the unit so we can help you with free do-it-yourself tips and/or an estimate.
Posted on Nov 26, 2010
How do I fix a microwave that counts down and does not turn on?
Appears to need a replacement door switch, might just be cheaper to get a new microwave if it is old.
They are made to close tightly and sealed so you are not exposed to microwaves. Not sure how safe you are overriding the microwave safety feature standing nest to it holding door.
Nov 30, 2015 | Microwave Ovens
Why does our new microwave not work? Can set the time and it counts down when we have pressed start but does nothing else.
There is a big fuse inside that thing. Check to see that it is not open. Could be that the magnetron, lite, and dish are all on the same circuit.
Sep 21, 2015 | Daewoo KOR6N9RR Microwave Oven
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Microwave won't heat or turn off unless I press the door
That would be a loose door switch mount, a failing door switch, or both.
See our file on door switch help here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 31, 2010 | GE Microwave Ovens
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
I have an nn2505c microwave that powers up but displays door open
Took it to a repair shop ,cannot be fixed ,no parts discontinued microwave.
Jan 19, 2010 | Panasonic NN-2505A Microwave Oven
Microwave light, turntable, and fan run after the door closes
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally by a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 29, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
