Question about Honda Garden
Working on a gx614/18hp honda - it was running one side was missing , put 2 new coils on and now i have no spark. all wires are together
    Problem Solver:
  • 13 Answers
How old is this unit?
Posted on Nov 06, 2010
I have a 95 honda shadow vt 600 it runs but its missing on the front cylinder any suggestions it has new plugs new fuel filter and fuel battery is about 2 years old but will run the bike
Try new spark plug caps. The resisters often burn out and cause poor running off idle. On some models the caps are part of the wire and are replaced as an assembly out of the coil. To save money use genuine NGK spark plug caps (about $5 each). They simply screw on to the end of the wire. If the cap reads higher or lower than 5000 OHM's it should be replaced. The copper core spark plug wire can be purchased in bulk for $1 to $2 a foot. It can be cut to length and used as an inexpensive replacement for the stock Honda wire/cap assemblies that sell for $25 to $45 each.
Jun 18, 2011 | 1994 Honda VT 600 C Shadow
Honda XL200R was running great but leaked oil bad so I tore it apart and replaced the head gaskets and piston rings, put it back together now ive got no spark. The head lite comes on when I kick it but the...
well your magneto is fine(because your headlight works when you kick it over) I bet it is something as simple as you forgot to hook up a wire since you had it all taken apart. since your magneto is fine that just leaves #1 coil....or....#2 cdi box.....to find the coil just follow the wire from your spark plug to it....your CDI box should be mounted under the seat( make sure all the wires are hooked up ) and check again.....
Aug 15, 2010 | 2002 Honda XR 200
I hooked up an amp for my stereo everything running fine till my fuse blew i put new one in on the main power line from battery to amp stereo works fine but now my valves miss fireing and heads winding bad...
Your amp as nothing to do with your car runnig bad. Your engine has a problem. It's miss fireing may be do to bad coil or even spark plugs or spark wires
Mar 06, 2010 | Honda Accord Cars & Trucks
Hi, I have a 1998 cbr 600f3. There are 2 coils on this bike for 4 cylinders and two wires coming in and 2 coming out(spark plug wires going out). I can only get one side of both coils to fire so the bike...
Hi and welcome to FixYa,
On the 2 ignition coils:
  • two wires coming in - black/white carries/supplies IGN + 12 to both coils and the ignition control module. Coil1 (left) is connected to the ICM by the yellow/blue wire while coil2 (right) is connected through the blue/yellow wire;
  • 2 coming out - left coil powers 1 & 4 while right coil powers 2 & 3;
  • 1 &4 will fire together; so with 2 &3.
Good luck and thank you for asking FixYa.
Nov 11, 2009 | Honda CBR 600 F(3)T Motorcycles
No spark on my 1985 cr250r
Start by...try another plug?
see that the coil wire that goes to the plug is clean, and not damaged or torn. If you have a kill switch, unplug it. (The harness usually has connectors about a foot and a half away from the switch)
Aug 14, 2009 | 2003 Honda CR 250 R
1980-gl1100-honda goldwing-no spark at plugs-
using a meter check your engine to frame ground
your testlight is completing the missing ground wire connection; allowing the spark to jump to ground
Jun 03, 2009 | 1980 Honda GL 1100 Innerstate Gold Wing
Car engine misses.
replace the coil with a Honda coil. never buy after-market ignition parts with Honda's always buy genuine Honda parts. not only will it work better...but its actually cheaper in some cases..plus they have a much better warranty than most auto parts stores. this rule applies to Honda's and Toyota's Ignition system parts. I had similar issues with my old 1989 Honda accord. As an added measure apply "Di-Electric Grease" into all spark plug wire boots to help seal out any moisture (both plug ends and distributor ends). hope this helps.
Mar 14, 2009 | 1992 Honda Accord
Missing in every gear..
you have to see if the coil pack fire up do you have spark coming out of the coil pack cylinder 2 never mind the other code the missing cylinder make the other sensor malfonction check if you have spark coming out of the coil pack if not change the coil pack if you have you spark check the compression let me know pierre please dont rate right away we work together to fix our problem because i whant you to get our car running good and i whant a fixya anything else is bad for me thanks pierre
Feb 25, 2009 | 2002 Mitsubishi Lancer
1994 bonneville misses especially at speed and acellerating
good chance you may have a bad coil, you can check by disconnecting the plug wires at the coil to see if your getting any spark, if your not seeing any spark when car is running your coil is bad. be sure to do disconnect the plug wire when engine is not running and key is off!
New coils run around $26.00 easy to change out, you only need a nut driver, 2 small bolts.
Dec 03, 2008 | 1994 Pontiac Bonneville
91 Honda Accord No spark
If the timing belt is damaged(broken or missing teeth) you will get no spark. One easy way to tell is that many times the engine will sound different as it turns over, than it used to.
Oct 05, 2008 | 1991 Honda Accord
Garden Logo
117 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
