Question about Asrock 939NF4G-SATA2 Motherboard
Hello i need to know how to connect reset sw , power sw , powerled , speaker and other with 939NF4G-SATA2 i try to connect it but i can't thankyou
2 Suggested Answers
CreativeTECH
  • 1719 Answers
SOURCE: cabel connect problem on the bord power sw reset
Please refer to the Product user manual. You can download it from the following link: -
http://europe.asrock.com/manual/775Dual-880Pro.pdf
Hope this helps!!
CreativeTECH
Posted on Nov 14, 2010
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
Where does the HDD Led, Power SW, Reset SW, and Power LED plugs go on the ECS GeForce6100SM-M motherboard
You'll need the manual for this MB. If you do not have it you can download it from the link provided;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Manual&MenuID=1&LanID=9
You'll also need Adobe reader to view the manual. Download Adobe here; http://www.adobe.com/products/reader/
Open to page 12 and zoom in with Adobe if needed. See pages 4 and 5 for location of, PANEL1.
Wire colors do vary from case to case. Colored wires are more often positive where white is common for negative. As you look at you're case wires you will find one color in common with most of the jumpers. This common color will be positive.
The internal speaker wire colors are red for positive and black for negative.
Main Web Page for ECS GeForce6100SM-M (1.0)
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailId=685&DetailName=Feature&MenuID=1&LanID=9
Take you're time.
Mike
May 12, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
Conectoes Led
You will get a much faster answer if you ask in English, the same language this website is written in.
Aug 05, 2009 | AOpen AX45-V (91.88I10.004) Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Panel 1 settings
Hello ocea, Here is a link to the manual: ftp://ftp.biostar-usa.com/manuals/M7VKF/M7VKFmanual.pdf Here is a picture of the front panel settings:
Oct 14, 2006 | Biostar M7VKF Motherboard
Asrock 939NF4G-SATA2 Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
