Question about Kitchen Ranges
How do i wire an NHP RCCB 2P 6KA 30MA 40A MOD6
What is the value of p if 2p/12=58
Let's work it out.
2p/12=58
2p/12*12=58*12
2p=696
2p/2=696/2
p = 348
Now let's check it
2*348/12=58
696/12=58
58 = 58
Always work out the equation to your final solution.
Semper Fi,
Z
Feb 13, 2018 | Homework
2005 odyssey wiring diagram. Need to discover what 40A fuse BackUp Circuits is
I show a 40A fuse 20 in the underhood fuse relay box that connects to 15A fuse 12 in the driver's underdash fuse/relay box (perhaps as a backup?)
Oct 09, 2016 | 2005 Honda Odyssey
Why wont the top 30 amp breaker won't reset?
YES!
New breaker is cheaper than a service call and quicker than tearing the dryer apart.
Jul 10, 2014 | Cutler Hammer Bq Circuit Breaker Bq230240...
99 yukon battery will not stay charged brand new battery
with ampmeter take the current draw of battery max amp 30mA
if more than 30mA remove fuse one at a time and watch if current draw go down.
when current draw go down on a fuse than that is the circuit that drain your battery
Oct 18, 2013 | 1999 GMC Yukon
Where are the side impact sensors located on a 2001 honda accord?
Usually at the base of the 'B' pillar (between the doors) behind the plastic trim.
______________
maxiscan ms509
Sep 12, 2012 | 2001 Honda Accord
As load is apply inverter trip
Tripping Of Your Inverter / Circuit breaker when you use Kitchen range Can be because of Overloading or because of Short circuit . If There is an Earth Leakage Problem , Your RCCB may trip if you installed one .
Get Checked by an Electrician . you may need to use a higher rated MCB and Wires .
Please Rate my answer and Support me
Nov 21, 2010 | Kitchen Ranges
Kitchen Ranges Logo
230 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
