Question about Lowrance LMS-337CDF GPS Receiver
Lowrance 530C gps unit. Gps unit not responding. The sonar is working. Turned the unit on/off but still getting the same message:"Gps unit not responding".
2 Suggested Answers
SOURCE: lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Posted on Jan 12, 2011
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance 330c gps not responding
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
My lowrance 520c GPS stopped working. When I turn it on it shows the last lake I was AT. And the trail marker does not work
I have a 525... Several things and go step by step... First, make sure your getting 12v of power to your "puck"... On the Lowrance site there is a step by step guide for testing. Just because your getting power to the main unit does not mean your getting power to your the gps module. There are three different power sources on these units. Main power, sonar and gps! If your getting 12v coming out of the data port then check power to the cords, and to the T... If all that is correct the its likely your gps module. You can order a new one directly from Lowrance customer support for 50% off the normal price as a replacement. They will likely upgrade you to the 4000 series. Comes with all wiring, T connector but not the resistor cap. Best time to call Lowrance is 8:15 am central time when the phones are turned on!
Mar 04, 2010 | Boating
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Apr 29, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
I have an lms-530c it keeps coming up gps module not responding?
Your GPS module is not receiving power (12volts). In the instuctions should be an additional red sheet of paper explaining how to wire it correctly. If the wiring is done right, check the 3 amp fuse.
Sep 01, 2008 | Lowrance GPS
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Mar 02, 2008 | Lowrance LMS-332C GPS Receiver
Lowrance LMS-337CDF GPS Receiver Logo
80 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
