Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking from detergent drawer - Whirlpool Duet GHW9150P Front Load Washer
  • 3 Answers
Have someone disassemble the internal hose to check for a clog in the line. The paper liner from a bleach container was the problem with my own washing machine. After several other chacks my husband had to remove it to spot the culprit. This was hard to spot and check for because it is thin, not viewable, and unexpected. We first tried fishing for any blockage, and there was no way of knowing. Hope it helps
Posted on Nov 06, 2010
Detergent dispenser drawer leaks.
give the draw a good clean by pulling it out, and check the level of the machine
Mar 15, 2014 | Hotpoint Washing Machines
My washing machine is leaking from under the detergent drawer and down the front of the machine. Any ideas?
Make sure that the drawer is clean, sometimes soap powder (detergent) can clog up into a lump and as water is sprayed into the drawer its can spray up around the top and down under the drawer.
Take the drawer out all together to get a good look inside it and into the drawers catchment area.
Mar 29, 2011 | Washing Machines
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
Intello washer leaking water from detergent drawer. model no. WM10402F would like to know if a part needs to be replaced or would anew machine be better. the water only leaks when water comes into the...
Are you sure it is coming from the detergent drawer? It could be from your inlet water valves. They are very easy to see. Two screws on the rear of the machine will let you slide the top back and expose the componets.
Dec 29, 2009 | LG WM-2277HW Front Load Washer
Front load washer leaks from the detergent drawer in the front
try taking the drawer out and clean it thoroughly, including the underside of the drawer, then clean the inside of the machine where the drawer fits into. Sometimes a build up of dertergent can casue this problem
Dec 28, 2008 | Kenmore 46462 Front Load Washer
(front load ATF6000ES) is constantly leaking detergent
the loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Leaking detergent
Sounds like the back of the soap drawer or inlet hose is partially blocked. Check whether junior has posted a toy car in the drawer
Oct 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
102 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
