Here it is: - EVERY time I use the Sustain/dumper pedal, all the note are shifted one semitone up (like bend +1/2). (It is like the Pedal act NOT as a sustain pedal but as a Assignable Pedal with a sort of feature) - This occurs for every sound, except the first one from COMBI - The Dumper pedal is attached to the "Dumper" jack and NOT to the ASSIGNABLE Jack. We lost EVERY SOUND, ALL...but the weird thing that the sustain keeps the note one semitone up REMAINS!..
    Problem Solver:
  • 12 Answers
Kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
Posted on Nov 06, 2010
Hammond sk1 foot switch is set to toggle Leslie effect between fast and slow. How do I change it to act as damper sustain pedal or other function such as glide?
Thre is a sustain pedal jack next to the foot switch jack. The pedals used are different. The foot switch is a latching switch, the sustain pedal is a momentary.
Dec 29, 2016 | Hammond Music
I replaced sustain pedal jack...now sustain is on ALL the time, even with pedal unplugged
When you replaced it, you either have the wrong jack, wired it wrong or it is shorted out where you connected it. Recheck the connections.
Dec 18, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
Casio Keyboard CTK700 The sound does not sustain when the key is pressed for 4 notes. How to rectify the same
sustain is typcially a product of the sound you have chosen, If you have a sustain pedal you can sustain any sound. you may also have some choices on the switches that allow special sustain, but I dont own a casio keyboard (I have yamaha) but they are nearly the same in operation. The easiest way to get controllable sustain is by plugging in a sustain pedal
Mar 24, 2011 | Casio Computers & Internet
A bought an Yamaha DGX 640 grand a week before and the note sustain for a longer duration and overlaps with the current playing notes. I checked the sustain in the function setting and it is also showing ...
The function setting is for the PANEL sustain (Page 68 of your manual)
The other method of sustain is by footswitch or pedal option. See page 13.
If you use a footswitch, it needs to be a normally open contact type. If you plug a Roland type in, it is opposite polarity and will sustain UNLESS the pedal is pressed. Make sure nothing else is plugged in the sustain jack... headphones that are inadvertently plugged in there would sustain.
Mar 06, 2011 | Yamaha DGX640 Music Keyboard
Sustain is in reverse yamaha p-85
I have the same problem, But I have been using the same pedal since new. Infact it came with this pedal. Then suddenly it started doing this. Could I have changed soem setting by accident?
Jul 08, 2009 | Music
My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
May 31, 2009 | Roland Juno-D
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Aug 25, 2008 | Casio LK30 Note Lighted Keyboard
41 people viewed this question
 Grubhead
Grubhead
