Question about Reddy Heating & Cooling
Trys to start but fan wont turn it just clicks and moves 1/8 of an inch
  • rjkoziba Nov 09, 2010
    Its not the motor! Its in the circut board
  • 6,826 Answers
When this happens on a heater, the motor for the fan is bad and should be replaced, if the part is available.
Posted on Nov 06, 2010
  • 2 more comments
  • Duane Wong
    Duane Wong Nov 09, 2010
    I have a portable Quartz heater which requires a fan to move, and once manually moved the fan blade with a plastic pen from a safe distance. After that the fan worked until I think whatever was making it stiff in movement went away.
    However, I would say that if the fan is not working, replace it.
    I'm not sure what year, make, and model you have to research it further.
  • Duane Wong
    Oh, I just read that you have determined it's the circuit board!
  • Duane Wong
    The circuit board is what controls the fan, I gather.
  • Duane Wong
    What about the circuit board do you think is awry to cause the fan not to turn?
I have a 1996 chevy lumina and the temperature gauge keeps moving around unpredictably. The fans wont come on. We checked the fuses and relay switch. Could it be the fan motor, or temperature gauge
The gauge is supposed to move. Between 190 and 210 degrees. About a 1/16 to 1/4 inch movement with the needle. If it goes from middle(200 degrees) to hot(260 degrees) and back. Check the coolant level. Air pocket in the engine. Low fans come on at about 210 degrees. High fans come on at 225 degrees. High fans come on when the A/C is turned on. And it works.
Feb 16, 2015 | Chevrolet Lumina Cars & Trucks
550 ti3 wont start
sounds like bad start up capacitor
Apr 14, 2014 | Jandy Air Energy Heat Pump - 100,000 Btus
COMPRESSOR WONT STAY ON
You replaced the compressor? Sea Breeze
May 30, 2013 | Refrigerators
Red light indecator keeps flashing red
Flashing red is a fan fail . It is probly blinking like 3 short and 1 long blink. If so then most likely your tv needs to have a new dmd fan installed.
Also once that tv detects a stopped fan it must be unpluugged from the wall outlet and plugged back in to get it to even try to turn on again. Sometimes fans will kinda work after a few trys or when the tv gets moved around.
Oct 11, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Replaced water pump nd timing belt now car will not turn over to start it trys but wont fully turn over. how do i get it to start
timing is incorrect/usually have to find #1 cyl top dead cent then use camshaft alignment marks and then reinstall belt.
May 08, 2009 | 1994 Volvo 850
Crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
TV wont stay on
Sounds like a short somewhere in there. I see old pre-HD big screen sets going for well under $200 on my local craigslist, so look there for a good replacement, because the repair will cost more.
Or fork over about $500 for a good used HD projection set.
Apr 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
GE nautilus wont run
These motors were famous for the seal sticking to shaft. If this is an older unit turn the fan on motor by hand until it breaks free. Do this with power off.
Nov 14, 2007 | GE Nautilus 24" Built-in Dishwasher
Heating & Cooling Logo
19 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
