Question about Panasonic KX-T7730 Corded Phone
Hello.... how are you? now i'm using PABX T824. i have install it already.now i need help from u. i want to assign new extension? now i don't know how to assign ? please tell me the detail of it?
cnavarro
  • 2460 Answers
SOURCE: Assign Extension Name
THIS MAY NOT APPLY TO YOUR SYSTEM SINCE THE U.S. VERSION TA IS NOT THE SAME.
From the System Manager's phone, go into programming and select program 604.
Posted on Oct 28, 2008
cnavarro
  • 2460 Answers
SOURCE: Switchboard PABX purchase
If you need 8x30, you start with a minimum of TDA-100. It grows to 96 ports and you would start with 8 lines and 32 digital ports.
Your phones become KXT-7633's, not the 7731's. On this side of the pond, it costs about $20 more per phone, but you gain the use of 12 extra buttons, 3 line display, and more features.
Your Panasonic TDA/TDE dealer can guide you.
Carl
Posted on Jan 15, 2009
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
cnavarro
  • 2460 Answers
SOURCE: CONTROL EXTENSION
By Class of Service (COS). It's an installer function, so you have to know how to get into programming and then you set up TRS levels.
Carl
Posted on Jul 26, 2010
cnavarro
  • 2460 Answers
SOURCE: dear friend i am using
This answers eaier in reverse order.
3. You find the drivers for the MC for your operating system. Our Pana dealer website has them, so I'd contact Panasonic for a solution.
2. The system needs programming. System programs 407-409 controls incoming ringing.
1. Did you install a 82493 CID card and programming?
Carl
Posted on Mar 26, 2011
Uniden troubleshooting
was the old phone connected to a Private Automatic Branch Exchange P.A.B.X like for example a comander system if so the new phone would have to be a PABX type phone extention type. I suspect the Uniden phone is not compatible with the PABX extension socket.
http://www.excitingip.net/291/ata-analog-telephony-adapter/
http://www.kosmaz.com/ata.htm
http://www.cisco.com/c/en/us/products/collateral/unified-communications/ata-186-analog-telephone-adaptor/product_data_sheet09186a008007cd72.html
I do not know what phone system you are using you might want to find out the model number of your PBX device and research if it uses VOIP = I can only guess that this is the situation
Sep 01, 2014 | Radio Communications
How to assign trunk lines on NEC SL1000 Keyphone System?
Try posting here:
http://www.tek-tips.com/threadminder.cfm?pid=937&page=1
Dec 07, 2012 | NEC PABX SL1000
How to assign password for the extension not to make international calls
It's not a password, it's a restriction. You change the Class of Service for the phone and put in the international code as a restricted digit.
Check your Programming manual for the system.
Carl
Nov 26, 2011 | Panasonic KX-T7730 Corded Phone
Need an installation and setup guide for tmc soho m4810.
you have to assign an ext to the phone.Press Program and extension button to assign it to an extension.
all phones have to have different assigned ext (obviously)...
To cancel stored extension(to change) Press program, press PAGE twice, press mute.
I need the users guide!!! have quite a few install and set up guides - I just need the users guide!!! need to change time and other things!!!
Please help...will trade...
Jun 30, 2009 | TMC M4810 NON-KSU Corded Telephone
Nortel 7310 voicemail will not reset
You dont have the EXT of mailbox 222 assigned to ext 222. Go under F983 press mbox press chg press 222 press ok press next it was say EXT: see what ext is assigned to put in 222 press change enter 222.
If it tell you that 222 is already assigned you have to find the mail box it is assigned to. Usually involves checking every Mbox starting with 221
Hope this helps.
Apr 14, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Name Display NEC DTerm Series i
It is changed via MAT or MOC programming. See you PABX Technician.
Mar 27, 2009 | Lands Phones
Interconecting 2 Panasonic KX-TDA 200 & KX-TDA600
You are asking for some very advanced setup features, as far as connecting them you need the IPGateway cards. They are cat5 cards that will do the trick. However programming the setup to do what you want will be VERY time consuming and not to easy to walk someone through. On-site tech is highly recommended for that much programming and work.
Feb 24, 2009 | Panasonic KX-TDA0410 (KXTDA0410) Network...
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
Panasonic KX-T7730 Corded Phone Logo
204 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
